Old 07-28-2015, 11:56 AM   #11
When you say extension cord and three prong plug, so you mean you plugged into 110 or 30 amp. If 110, do not run your air unless it is a side mount like you would have in your house window. It may ruin your compressor.
vanreever is offline   Reply With Quote
Old 07-28-2015, 08:04 PM   #12
Evereddie's Avatar
It all comes down to voltage and voltage drop. If you check your voltage when running the air and it is 104 or above you are OK. Lower than 104 then you need bigger power cables, somewhere. Don't run the air if 104 or lower.
Evereddie is offline   Reply With Quote
Old 08-02-2015, 09:53 AM   #13
They had me on too low of a hookup switched to a correct 30 amp site and all is well
jaxenro is offline   Reply With Quote
1809s
