Mini Lite 2104 inline battery fuse
TT is 2012 MiniLite 2104.
Does anyone know where the inline fuse between the battery and the power converter is located? I've looked and can't find one but cannot believe that it isn't there somewhere.
Had a huge power surge while trailer was hooked into shore power. Few weeks later, as I was leaving for the day, I heard the propane detector chirping. Quick look showed interior lights barely glowing. Okay ... chirping because of low battery.
Have had a chance to look now. No blown fuses in the converter. All of the 120VAC stuff is working fine. Battery is now completely dead and am charging now (removed from TT and on separate charger) to see if it will hold a charge. If it does, and if the inline fuse is good (when I find it), it will probably mean the surge fried the converter -- but I need to find that darn inline fuse first.
Thanks for any input.
