Old 10-29-2014, 11:50 PM   #1
Mini Lite 2104s Back Flush?
Purchased this trailer a couple of weeks ago and took it camping this weekend. Before leaving and after dumping the black tank, I attached a hose to the back flush hose connector. The hose screwed on properly, but water would not flow in? It acted like it was pressurized as when I disconnected the hose, water sprayed every where. The black line was open at the time, so I don't know what would have caused this? Any ideas?
Bump is offline   Reply With Quote
Old 10-30-2014, 02:42 AM   #2
Just a member
kandl's Avatar
Check out this recent thread:
Blank tank flush
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 10-30-2014, 09:50 AM   #3
Thank you.
Old 10-30-2014, 10:17 AM   #4
Was the Black tank flush installed aftermarket? the 2104s were not supposed to be able to be ordered with a black tank flush. At least that's what my dealer and thier website said
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is online now   Reply With Quote
Old 10-30-2014, 10:19 AM   #5
I just bought it and it's not an after market. The trailer is a 2015 and it was the first time it was ever used so I can't understand why it would be clogged?
Old 10-30-2014, 10:20 AM   #6
On the forest river site it says the mini lite has black flush as standard.
EXTERIOR FEATURES
Fully Laminated Aluminum Frame (Floor, Sidewall, & Roof)
Insulation Factors R-7 Side Wall, R-12 Floor and R-14 Ceiling
Radius Roofs w/ Interior Vaulted Ceilings
Vinyl / Rubber Composite Roofing Membrane
TV Antenna w/ Cable & Satellite Hook-Up
Laminated Fiberglass Sidewalls
Distinctive Black Exterior Trim
Electric Slide-Out (All Slide Out Models)
Lower Front Diamond Plate Panel
Decorative Frame Skirting (2104S, 2504S Only)
Entrance/Screen Door
Large Assist Grab Handles
Radius Corner Windows and Doors
Large Dinette Picture Window (N/A 1901, 1905, 2505S)
Outside Grill Prep
Outside Speakers
Outside Shower
Outside Antifreeze Stations
Two-20 Lb Gas Bottles (1901, 1905, 1907 Only)
Two-30 Lb Gas Bottles (N/A 1901, 1905, 1907)
Molded Bottle Cover
Surface Coated Steel I-Beam Frame (N/A 1901, 1905, 1907)
Stabilizer Jacks
Torsion Axle, Rubber-Ryde Suspension
Easy Lube Axles and Nev-R Adjust Brakes
Radial Tires w/ Nitro Fill
Double or Triple Entry Step
Black Water Flush
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 10-30-2014, 10:35 AM   #7
interesting... I have the 2015 Flagstaff version, and I didn't get one.
Not only that but it was something I asked about since it was factory ordered
Thanks for the info guys
Old 10-31-2014, 01:07 AM   #8
Just a member
kandl's Avatar
Brand spanking new! I'd be engaging the dealer to make it right.
Old 10-31-2014, 06:37 AM   #9
I spoke with the dealer yesterday and I'm going to remove a back panel in the back closet and look at the back flush hose to see if it's "pinched". It might be something I can fix and save me the 100 miles to drive it to the dealer. If it is damaged beyond my repair ability the dealer said to bring it back and they will fix it.
