Old 04-08-2015, 07:04 AM   #11
No problem. Main TV is a Toshiba and the second is a Furrion.
We didn't want to have to take the Toshiba loose to take outside.
Have fun.
________________
MKClark
MKClark is offline   Reply With Quote
Old 04-10-2015, 06:40 AM   #12
53flattie's Avatar
MK - I really appreciate all the help. You're a gentleman and a scholar.
2015 Rockwood 2306
2006 Toyota Tacoma
53flattie is offline   Reply With Quote
Old 04-10-2015, 08:11 PM   #13
If you are not going to use the TV in the RV for outside use why not buy a cheaper mount for the inside unit. Then just use the existing detachable mount for your outside TV. Probably 1/2 the cost of a second detachable mount.
Harmini is offline   Reply With Quote
Old 04-11-2015, 07:29 AM   #14
53flattie's Avatar
I'm embarrassed that I didn't think of that... Simple and cheap - the two best qualities you could ask for!
My only concern would be attaching the new mount inside. Surely the factory has some reinforcement behind the interior mount?
2015 Rockwood 2306
2006 Toyota Tacoma
Old 04-11-2015, 08:10 AM   #15
If you mount it in the same location as the existing Mount I'm sure that there is support bracing installed.
2306, mount, television
