Old 02-03-2017, 09:41 PM   #1
Question MIni Lite 2503S thinking of adding wood shelves to wardrobe
I remember seeing example of how someone cut wood to match shape of the inside of the wardrobe closets on either side of Murphy bed & then added 2 shelves. No drilling into RV wall necessary as the support for shelves was now attached to the side added. But now I can't find it. Any ideas how to do this??
Gottaluvlife is offline   Reply With Quote
Old 02-03-2017, 09:49 PM   #2
If you find it or figure it out, please post back. Might be something my DW would want.
2011 Traverse LT, 3.6L, FWD
Old 03-21-2017, 11:21 PM   #3
Adding shelves
To add shelves in my 2304 I cut my shelves then cut some narrow legs like 3/4 by 3/4 and using double sided foam tape stuck the 4 legs in place and set the shelf on them. I also did this for my kitchen cupboards.
Bandit114 is offline   Reply With Quote
Old 03-25-2017, 09:30 AM   #4
One easy way is to hang a folding shelf you can get at target or Walmart.
They are made to hang in a closet and you can cut the bottom off if it is too long. The ones I have used have a hard plastic floor on each shelf. The nice thing is you can take them out when needed. Just an idea.
rcguy is offline   Reply With Quote
lite
