Old 03-03-2015, 12:45 PM   #1
Mini-lite 2504s and Andersen levelers
We have a mini lite 2504s and I have been considering getting the Andersen levelers. I have been doing some research and it looks like I'll need to trim some of the end off to fit these. I would appreciate any advice from you 2504s owners. If you are using Andersen levelers, can you please help confirm how much you need to trim off, and does it still work ok?
I'm apprehensive about paying ~$80 and then have to immediately cut them up.
nc_camper is offline   Reply With Quote
Old 03-03-2015, 01:23 PM   #2
JohnF's Avatar
I have the Anderson levelers and have used them all season. I had to cut off a lot to make them fit between my tires on my 21FBRS. I think they will come in real handy for a flat tire as you can put one under the good tire, pull forward or backward and lift the flat into the air. However, I do not like them for leveling the trailer. Once your tires are “ramped” into place to level the trailer, gravity is trying to pull the camper back to the ground. This requires you lock the tires into place well before disconnecting the hitch. It works but is not a good situation in my opinion. I have resorted to using the square plastic building block type and will keep an Anderson wedge onboard for a flat tire.
My 2 cents,
John
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 03-04-2015, 08:44 AM   #3
Charliec's Avatar
We have a 2504s and we use the Anderson levelers. I cut off the max amount and I believe it was 4 inches and they work fine. They come with an insert that is a guide to how much you can cut off. I have to use a hammer to get the one between the wheels but it is easy. They really stabilize the trailer after you get the chocks in place. Great way to level IMO.
Charlie C
2012 Ford F-150
2015 Rockwood 2504S
Charliec is offline   Reply With Quote
Old 03-04-2015, 07:19 PM   #4
We also have a 2504s and the Anderson levelers. I had to cut off the max on one and it's still a tight fit but they work well in my opinion. Fast, easy and effective.
Rob & Julie with Sadie the Shih-tzu
2017 Rockwood Ultra Lite 2902ws
2017 Ford F150
RShelton is offline   Reply With Quote
Old 03-05-2015, 10:25 AM   #5
AKA: 'tiredTeacher
awellis3's Avatar
Don't do it. As you've read in two previous posts, you must cut and trim quite a bit to get one to fit between the tires. You'll also note that Charliec says they "work fine" but he uses a hammer to make them work fine.
Trimming also creates a steeper angle on the leveler making it prone to sliding on sand, grass and asphalt.
I'll send you mine (already trimmed) if you pay the shipping.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 03-05-2015, 11:08 AM   #6
Charliec's Avatar
Pay the freight and get them from awellis3. It's a cheap way to try them.
Charlie C
2012 Ford F-150
2015 Rockwood 2504S
Old 03-09-2015, 03:26 PM   #7
Thanks for all the input and the offer on these. I'll send you a private message.
-Eric
