Old 03-10-2011, 05:40 PM   #31
very nice trailer Sherdep.I noticed that you have a big grab bar to assist your entry. Was it there when you bought it. It is the first time that I see it on a minilite. I know that it come standard with the r pod trailer.
capucine is offline   Reply With Quote
Old 03-10-2011, 05:55 PM   #32
SCannon's Avatar
I second capucine, very nice. What is the problem with the trailer/hitch? I see you had to invert the hitch mount but the trailer looks level and seems like adding a lift kit to the TT axles is not the best way to go. I have the 14'' wheel option and the TT rides beautifully.
These Mini Lites are sweet
SCannon
SCannon is offline   Reply With Quote
Old 03-10-2011, 06:52 PM   #33
sherdep's Avatar
Thanks for the compliments
The grab handle was installed by the dealer - I had it added on along with two Max Air II's - being a single dad and pretty busy it was easier to just have the dealer install and besides I know it was done right and if I have any issues they cant say I installed it wrong either.
My 4 year old has been using the grab handle to get in and out - she wouldnt be able to reach the regular handle.
I have 7" inches of drop - the trailer isnt level it is actually up about 1/4" or so high and that's even with a full 36 gallons of fresh water - there is barely any pressure on the spring bars so I need to go to the next length drop which is 8 3/4" and then put more pressure on the spring bars to lift / level the camper and have more force to keep the trailer from swaying. At 65 the trailer sways and I can feel it and dont like that feeling of "waddling back and forth"
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 03-11-2011, 06:33 PM   #34
This is the problem that you get when the weight on the tonge is too light. I have experienced this issue many times with some of my older trailers that were to light on the tonge. Even with an anti sway bar it was barely okay specially when the 18 wheelers were passing me on the highways.
Old 03-11-2011, 09:31 PM   #35
sherdep's Avatar
I ordered the next size drop shank so I can lower the front down some and put more pressure on the bars to reduce some of the sway - I know the bars dont have enough pressure and the front of the trailer is high due to the drop shank I presently have isnt enough - will be fixed very soon
Old 03-26-2011, 12:13 PM   #36
momtovn's Avatar
matt, i notice you had said something about wheel size and gears, we have 35a'tires ( i believe) and the the wheel size is the ones that come with the camper, we did not upgrade to the 14" and our gears are 3.55, that should be ok, right?? new to all this remember...lol
Chris, Ami, and our 2 kids ages 9 & 11
2011 Flagstaff 23lb
tow vehicle-2008 Ford F150 XLT 4x4 5.4 engine
gear ratio
3.55
momtovn is offline   Reply With Quote
Old 03-27-2011, 03:52 PM   #37
sherdep's Avatar
Glad you are asking questions - have to learn somewhere and what a better place then with people that know and wont give you are hard time about it
35" tires are on the truck (305-70-18) not the trailer
Look at the side wall of your tow vehicles tire and see what the size says if it 20" rims (275-60-20 - 33 inch tire) you will most likely have 3.92 gears and not the 3.55 gears - if you have the 17" rims (not sure what the stock size is) then probably have the 3.55 (If it's a Dodge)
13" tires come standard on the trailer unless you upgraded to the 14" wheel (205-70-14) with double step option
Old 03-27-2011, 04:01 PM   #38
sherdep's Avatar
I just got back from my First "real" trip with my TT
I have a few things to work out but overall was a very pleasant experiance
If any of you 2306 owners would check this out and let me know if yours does this as well or some dufus miswired it - when I am connected to shore power and the turn the light on the top bunk the fan in the power center turns on and off when you flick the light on and off - it doesnt do it on battery power.
I am going to put a diffrent shower head and shower curtain rod also - the head leaks even when the button to stop water is pushed and while taking a shower the curtain grabs you so gonna put one of the half rounded rods on to push the curtain away from you when in the shower.
Name:	Truck and trailer down the shell road.jpg
ID:	5012   Click image for larger version
Name:	Truck and Trailer setup.jpg
ID:	5013   Click image for larger version
Name:	Dakota sitting in her chair.jpg
Old 03-27-2011, 06:05 PM   #39
We have the 2502s, towing with an 04 Tacoma. E2 anti sway bars and weight distro set up. No sway, no problems. Run around 65 mph or so since we only have a V6. We love it!
ID:	5026   Click image for larger version
ID:	5027   Click image for larger version
toadswife is offline   Reply With Quote
Old 03-27-2011, 06:06 PM   #40
03 Tacoma...
