Old 09-27-2017, 07:21 PM   #1
Mods to New Windjammer
We recently purchased a 2017 Windjammer 3006WK. This post will detail completed and future mods, and will be updated with pics as they are completed.
Completed mods:
MaxxAir II vent covers on bedroom, kitchen, and bunkhouse vents
Carpet step protectors
Sewer hose storage tube
TV on adjustable arm mount in master bedroom
Future mods:
remove water filter housing, relocate to outside
install RV central vacuum where water filter was
Install Progressive Industries hardwired EMS with display
Smart RV Products Fridge-Fix fans
Vent fan in kitchen vent
Install gas lift struts on upper bunk
Install lock to secure outdoor fridge door while traveling
Replace analog thermostat with digital thermostat
Possible Mods:
Add Air Conditioner in master bedroom
Add fans in refrigerator roof vent
ID:	152699   Click image for larger version
2017 Rockwood Windjammer 3006WK
dankirk is offline   Reply With Quote
Old 09-28-2017, 08:23 AM   #2
SeaDog's Avatar
You might give some thought to adding a 2 gal pressure tank in the space where the water filter came out of. I did that to mine and its is one of the better mods I have done.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 11-05-2017, 08:56 PM   #3
Today I finally had some time to work on our new trailer. I added a FridgeFix refrigerator fan, upgraded the thermostat to a digital thermostat, installed a LevelMate Pro, added a door lock and velcro to secure the shelves in the outdoor fridge, and installed gas struts for the flip-up top bunk bed in the bunk house.Click image for larger version
ID:	155855Click image for larger version
Old 11-06-2017, 12:20 AM   #4
Those fans seem like a good idea. Do they help? Are they battery powered or do they run off of 12 volts? Jay
Jay2504 is offline   Reply With Quote
Old 11-06-2017, 10:01 PM   #5
They are 12V. The power wire is ran out along with the thermistor wire and it connects to the fridge 12V input behind the service panel.
Old 11-07-2017, 08:47 AM   #6
Thanks a lot. That seems like a better option to me than a battery powered fan
Old 11-07-2017, 11:48 AM   #7
I added a computer fan to mine as well. I wired it to the intererior light switch to work opposite of the light bulb, ie on when door is closed, off when door is open.
I hooked up the positive side to the source side of the door switch, then hooked up the negative side to the light side of the door switch. That way it grounds through the light bulb. When the door is opened and the light bulb turns on, it interupts the ground and turns the fan off automaticlly so you don't push all your cold air out the bottom of the fridge while it is open. Then when you shut the door, the fan turns back on automatically.
Abendage is offline   Reply With Quote
Old 11-07-2017, 01:55 PM   #8
K7TNT's Avatar
(Sewer hose storage tube) what size did you go with? I may do the same mod. Thanks
Got are first TT, a 2017 2506S. TV, 2016 GMC Canyon Duramax Diesel Loving it!
K7TNT is offline   Reply With Quote
Old 11-07-2017, 10:30 PM   #9
It is plastic fence post with a slide out drawer made from plastic rain gutter. I believe its 4" X 4". I made it for our prior trailer a few years ago. If I made it for the new trailer, I would have used black.
Old 11-07-2017, 10:32 PM   #10
The fence posts are usually 5" x 5"
2011 Traverse LT, 3.6L, FWD
windjammer
