That's the little bugger that went bad on my V lite at about 1 1/2 months old, due to corrosion or rust. They said when my unit was delivered to the Florida dealer from Indiana, road salt may have caused this because of the winter weather. The junction block/relay on mine had a small reset button on it, but it still needed replaced from the rust. The new one has no reset button on it. There is also 2 green 30 amp fuse holders just beyond this piece for the slide out power. They are sealed closed from the weather, but if your electric slide out motors don't operate for some reason, this is probably the culprit! I have replaced one already. Randy
 '08 V-lite Flagstaff 30WRLS
'06 Ram 1500 QC hemi  Reese dual cam sway control,
K&N series 77 intake, Hellwig pro series helper spgs.
'04 Durango Limited Hemi, '72 Mach One 351 cj
