Old 06-01-2014, 10:43 AM   #1
Need Advice on Hitch Weight
Have a 2012 F-150, 3.5 L, V-6, Eco-Boost, 3.55 axle, 145 WB, super crew, with towing package.
Looking to buy a 2014 Windjammer TT, 3025W, 971 hitch weight, 7,559 dry weight, 34' 5" length.
Will my truck adequately pull the trailer?
Will sway be a problem considering length?
Will hitch weight be a problem?
Not finding many answers. Don't want to overload the truck...especially concerned about hitch rating.
Any advice?
Texasrose is offline   Reply With Quote
Old 06-01-2014, 01:00 PM   #2
Pretty sure payload may be a problem with that setup. You're looking at a 9000 lb. trailer once it's ready for camping and to me that is out of 1/2 ton territory.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 06-01-2014, 01:12 PM   #3
Any advice?
Welcome,I know your new,but please do a Search at the top under many names (Will my 1/2 ton pull a ??) and you will come up with Many Days of reading! If still lost come back here,and the Pages will grow more,but NO solid answers! Youroo!!
Old 06-01-2014, 03:54 PM   #4
You cannot tow this trailer - Ford specs require a 3.73 axle ratio and then a maximum tow capacity of 5700lbs.
Their specs do not list ANY towing capacity for the 3.55 ratio. You will need a trailer than weighs no more than about 4500lbs empty and a lower axle ratio.
FROM THEIR SPEC SHEET
Maximum Loaded Trailer Weight assumes
a towing vehicle with any mandatory
options, no cargo, tongue load of 10-15%
(conventional trailer) or king pin weight
of 15-25% (5th-wheel trailer) and driver
only (150 pounds). Weight of additional
options, passengers, cargo and hitch must
be deducted from this weight. Also check
Required and Recommended Equipment ---
F-150 mandatory option
• For trailers over 5,000 pounds – Trailer Tow
Package or Max Trailer Tow Package
cadman99 is offline   Reply With Quote
Old 06-01-2014, 04:38 PM   #5
Ummm.... no.
Where did you get that info?
The towing capacity for pretty much every configuration is available online to whoever wants to find it. This includes the various gear ratios.
Here you go:
https://www.fleet.ford.com/truckbbas...FLRVTT_gde.pdf
I still think the OP has too much trailer for his TV but no need to give him bad info like you're trying to do.
Old 06-01-2014, 04:54 PM   #6
Engineer of Crazy Train
ChooChooMan74's Avatar
That is a heavy trailer with a real heavy tongue. I bet close to 9000lbs ready to camp with 1100 to 1200 on the tongue.
Sent from my Samsung Note 8 Tablet using the FRF Android App!
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 06-01-2014, 04:59 PM   #7
fonzie's Avatar
Originally Posted by pappcam View Post
Ummm.... no.
Here you go:
X2, read PDF file and calculate using all info required from your particular truck.
Fonzie
Old 06-01-2014, 05:50 PM   #8
pappcam - that is exactly where the info I provided came from.
Old 06-01-2014, 06:07 PM   #9
fonzie's Avatar
The 3.5L ecoboost with 3.55 gear ratio can pull between 9600 lbs and 9800 lbs for the configuration above depending if a 4X2 or 4X4 as it is not provided by OP. Other factors might decrease this rating.
Fonzie
Old 06-01-2014, 06:24 PM   #10
My beast would be happy with it. I pull an 8289 just fine. I have two wheel drive, the 3.73 and have air shocks. The beast is amazing going down steep hills and the power going up hill is nice. I am in idaho so have hills a plenty. Fifth wheel vs bumper. I do think a fiver pulls easier. I love my beast but I also have been pulling stock trailers for years so am used to a trailer following me.
bobandsue is offline   Reply With Quote
Old 06-01-2014, 11:06 PM   #11
You must be looking at the wrong page:
Old 06-02-2014, 01:00 AM   #12
asquared's Avatar
The best way to find out exactly what you can tow is to load your truck up ready to camp with all passengers, pets, gear and full tank of fuel and go weigh it at a Cat scale. Weigh each axle on a separate scale pad so you can learn those numbers as well as overall truck weight. Take the actual truck weight and subtract it from your trucks gcwr to get your adjusted towing capacity. Take the trucks actual weight and subtract it from the truck gvwr to get your available payload. Take your rear axle weight and subtract it from the max RAWR to see how much room you have for weight on your rear axle. Understand that your loaded tongue weight (not dry tongue weight) must be less than your available payload and your loaded tt weight must be less than your adjusted towing capacity.
Understand that you will never tow a dry or unloaded tt. If this is your first tt then you have no idea how much cargo you will add (average is 1000-1500 lbs) so it is safer to calculate using tt gvwr. Ideal tongue weight is 13-15% of loaded tt weight. So if you look at worst case scenario here, you are looking 9050 lbs tt gvwr x 15% loaded tongue weight = 1350 lbs. Realistically, at best you will be at the top of the trucks capabilities. I agree with the others, it is too much tt for the truck.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 06-02-2014, 09:20 AM   #13
Camper Less Camping
Cajun Po-Boy's Avatar
X2 and that length of a trailer is going to feel like towing a highway billboard with the 1/2 ton...definetly will have to make sure to have stiffer sidewall tires on the truck and a great (not cheap) WD hitch setup to help with sway, etc..
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 06-02-2014, 10:23 PM   #14
The comment from Cajun Po-Boy about towing a billboard is no joke. You really want to get your hitch setup right with that big sail behind you.
Newbies to the RV scene last spring, we bought our Windjammer 3008W and the dealer set us up with a EAZ lift WD hitch. Thinking everything was great to head home, got on the interstate and the first semi that passed us pretty much pushed us off the road just from the air coming off his rig.
I know I'm pushing the limits on my Titan with our trailer, but we've got it setup now where I feel confident pulling our Windjammer regardless how windy it gets.
Can't stress enough the importance of Sway control.
2015 Keystone Raptor 425TS full body paint
TV 2015 RAM 3500 MC 4x4 DRW w/ AC69RC HD Trans
Pullrite Superglide 2300 24k w/ OE adapter 25k
cobiker is offline   Reply With Quote
Old 06-03-2014, 06:43 AM   #15
I have the same TV. You have to know all your weights to come up with the answer. But in short, that's a lot of tongue weight, and don't know if your TT weight is loaded or not, you would be close if not over possibly. My loaded TT when leaving the barn, 5,500lb with 438 tongue weight.
10Boomer is offline   Reply With Quote
Old 06-03-2014, 07:49 AM   #16
Retired Trucker/43 years
Noneyerbusiness's Avatar
I tow a 3008W with my 1/2 ton .... using properly adjusted weight distribution hitch, with 4 point sway control, I have zero issues.
As for weight distribution, have a QUALIFIED technician set it up.
I have the 12000# version of this hitch .. all is good.
Equal-i-zer® Hitch - The “American Original” with 4-Point Sway Control™ and Weight Distribution
2017 Windjammer 3029W
2006 Ford F-150
HD 7700# tow package
Noneyerbusiness is offline   Reply With Quote
Old 06-03-2014, 07:57 AM   #17
As for weight allowed, my truck has the 7700# tow package. it can TOW, (gross weight, truck and trailer) up to 13,000 pounds. I have weighed it several times with different onboard loads, I have never exceeded 11,000 #'s ...... my major advise, get a GOOD brake controller for the trailer. I made the mistake of using a cheap off the shelf model, and trashed the front brakes on the truck.
I intend to install this controller before we begin our trip out west this August. (Unless someone has a better solution)
Prodigy P2 Brake Control - Cequent 90885 - Braking Controls - Camping World
2006 Ford F-150
Old 06-03-2014, 08:35 AM   #18
CLT
Next Gen Camperbot 5000XL
CLT's Avatar
I'd say towing experience might be a factor in this one. You have over 40 years as a trucker. Who knows what the OP has. Is this their first TT? Are they upgrading from a 30 foot TT? We don't know. BTW, go P3 on the brake controller. Many menu options and ability to change display color plus a nice "boost" feature. For the $20 difference it seemed worth it to me.
NO TV!!! NOW WHAT???
2014 Coachmen Apex 259BHSS
CLT is offline   Reply With Quote
Old 06-03-2014, 08:42 AM   #19
Well, there is that pesky truck diving thing, CLT. But I do know the setup I have works for me .. and thanks for the tip on the P3 ...
2006 Ford F-150
Old 06-12-2014, 04:20 PM   #20
We have a F150 Ecoboost with the HD package and 3.73 gears and we pull a 8310. I am pleased with the power of the Ecoboost and the amount of power to pull our trailer. Our problem has been with the hitch. We were adventurous and tried the new Andersen weight distribution hitch and it was terrible...so terrible that our dealer bought the hitch back. We installing a Blue Ox now and am anxious to pull the trailer in the near future.
skcerny is offline   Reply With Quote
hitch, weight
