Old 02-01-2015, 08:47 PM   #11
X2 Sorry
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 02-01-2015, 10:28 PM   #12
Platokidd's Avatar
I have a 2009 chevy 2500hd 6.0 6 speed and tow a 8500 lbs TT. Your gonna know its back there for sure and the trucks gonna work hard. I towed mine thru the hills of KY. and it did fine.
That said I would not feel good about taking my 8.5k unit in high elevation mountain towing.
If ya do tow it there, let me know how the truck does.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 02-01-2015, 11:49 PM   #13
It is going too tow the load just fine. Only issue is plan your fuel stops every 300 miles or so. Yes you will get more but not a lot more so plan and be prepared.
2015 Sandpiper 30IOK
2014 Ram 6.7 CC DRW
2006 Charger RT
X96mnn is offline   Reply With Quote
Old 02-02-2015, 03:31 AM   #14
BiigDaddy's Avatar
JKenney, I have a '13 2500 Savanna 6.0L 6 speed. I pull a 8327SS. You will definitely know it is back there, but it will tow it comfortably. We took it through the Smokies last summer and it was adequate. I stayed in the right hand lane with the semi trucks on those long 6 - 7% uphill grades, RPM's up around 3000, 98 degrees out, and kept up with them. So, yes the 6.0 worked hard but did the job. Flat land towing it is a solid, drama free drivetrain that works VERY well. Hope this helps!
2013 GMC Savana 2500 FBI Edition
2015 Rockwood 8327SS stuffed with 5 kids!
SE Michigan
Nights camped 2014: 48
BiigDaddy is offline   Reply With Quote
Old 02-07-2015, 06:10 PM   #15
2008 silv. hd.
use tow haul. watch trans temp. mine has airplane gears so good flat tow but not so good in the hills.
2OLDDIGGERS is offline   Reply With Quote
