Old 09-17-2015, 12:26 PM   #1
Need lug nut torque specs
I'm in need of lug nut torque specs. We have a MicroLite 23LB which I believe is the sister camper to the Rockwood 2306.
2011 MicroLite 23LB
2012 Ram 1500 Crew Cab
zinger60 is offline   Reply With Quote
Old 09-17-2015, 05:33 PM   #2
During my PDI, the tech told me 140 lb-ft on the aluminum wheels and 110 lb-ft on the steel spare. But I didn't see any numbers in any of the paper work I got with the camper.
So who knows?
2011 Traverse LT, 3.6L, FWD
Old 09-17-2015, 05:42 PM   #3
Left Coast
Was just look'n at the dealer 1/2 hour ago, on the new ones the tag you could read for alum wheels, said 140 lbs.
Old 09-17-2015, 05:47 PM   #4
So who knows?
Weird, didn't know the stud could tell the difference and max on a 1/2" stud is still 120lb/ft. I torque mine to 110lb/ft.
Old 09-17-2015, 06:24 PM   #5
Ok just got home and dug out the owners manual for the AL-KO axles and here is what they recommend Click image for larger version
Name:	ImageUploadedByForest River Forums1442532281.785723.jpg
2011 MicroLite 23LB
Old 09-17-2015, 09:14 PM   #6
It says "Always use the wheel manufacturers recommendation." But what is that??
Old 09-17-2015, 09:38 PM   #7
Commercial Member
It isn't the stud but fundamentals of wheel design.
Steel wheels basically function like big "Belleville washer" so we are looking at the force needed to deform and pre-load the stud tension.
Aluminum centers are depending the stretch of the stud to provide the pre-load as the solid aluminum does not deflect.
Wheel studs are basically Grade 8 hardware so they have a torque limit or you will over stretch them which can result in stud fracture. There are tables available for max torque based on stud size.
Also stud torque can be messed up if regular oil or grease is used so studs and nuts should be clean and only lubed with WD-40 or Never-Seize.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 09-17-2015, 10:11 PM   #8
Wire Wrat's Avatar
Owners manual has a section on tire safety.. Wildwood Heritage Glenn 299RE says to torque on final pass 85 -95 foot pounds. I had to buy tires on a trip with the old camper, and I torqued them to 100 foot pounds at the tire shop. 35 miles down the road, I decided to re-torque them.. good thing, they needed an eighth of a turn to get back to the 100 foot pound reading.. 50 miles later we got to the campground, and I went around again, and again got another eighth turn.. at home, I got true reading with no turn on the nut required.. So if you put new tires on, It might pay to look at them periodically.
Wire Wrat is offline   Reply With Quote
Old 09-18-2015, 04:18 PM   #9
satdog01's Avatar
While spring cleaning the Flagstaff in prep for Goshen trip, I found a sticker on the storage compartment by the jack handle that stated wheels where torqued to 90 ft-pounds. This is where the wheels were torqued to and checked prior to the trip when tires were replaced. Did check wheels in route and found 3 nuts out of the set that needed a bit more tightening. OC would be proud, carry torque wench and 1/2 sockets on TV on all trips! Have AL wheels on the Flagstaff.
satdog01 is offline   Reply With Quote
Old 09-18-2015, 05:56 PM   #10
It says "Always use the wheel manufacturer’s recommendation but do not exceed 120 ft/lbs on 1/2" studs. Never exceed the wheel manufacturer specifications."
Filthy Beast is offline   Reply With Quote
