Old 04-24-2012, 11:45 PM   #11
Dave_Monica's Avatar
I bigger truck and campers to carry everything in!
Dave
Old 04-25-2012, 12:53 AM   #12
Nothing on a camper is metric, do far. You do need the square drive screw driver. A spare tire, and enough stuff to change it on the side of the road. Fuses, maybe, but if yo blow a fuse, replace it, and it blows again, then you need a lot more. I carry a lot of tools in the truck, and hope every trip I never have to get them out.
Bottom line, how much do you want to try and fix, or just give up and go home.?
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-25-2012, 04:32 AM   #13
Steve Jackson
sideout1961's Avatar
I Agee on the square drive screwdriver. Every screw on the cabinets are square screws. Which I found out after one popped on my brand new camper. The hinges were so tight against the door panel that when I opened it the screw pulled right out.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 04-25-2012, 05:47 AM   #14
Oakman's Avatar
A cell phone to call ERS or Mobile RV Repair.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-25-2012, 05:54 AM   #15
Rugged Brown's Avatar
A bottle opener and cork screw.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 04-25-2012, 06:54 AM   #16
Herk7769's Avatar
Since no one mentioned it yet:
Battery maintenance:
In my battery compartment I keep a small bin with:
Face shield for splash protection
Wrench sized for terminal bolts
Rubber battery water bulb
Mirror for peeking into cells I can't see from the front of the 5th wheel
1/2 gallon jug of distilled water for topping off low cells
Plastic apron to protect my camping clothes.
Small fire extinguisher (an old Halon one - don't tell anyone)
$10 Volt Ohm Meter from Harbor Freight
Spare fuses for the inverter
Plumbing Compartment:
In addition to the 2 25 foot fresh water hoses -
Black color 10 foot "flushing only hose"
Flushing fitting - (brass check valve - on/off valve - brass check valve)
Channel Lock pliers for snugging a leaky hose connection
Spare hose washers and two spare brass check valves
Spare hose couplings (male-male, female-female, set of repair ends)
Hand Hose Nozzle for washing mud and stuff off rig and washing dog
Electrical Setup bag (plug in 120 VAC voltage tester, 30 amp to 20 amp adapter, 50 amp to 30 amp short cord)
HAM CALLSIGN - KC3FFW
Old 04-25-2012, 07:03 AM   #17
Crusader's Avatar
Mr. Monica is right....he'll need a bigger trailer...................
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 04-25-2012, 07:13 AM   #18
bailing wire here, WD-40, matches, test light. camper with extended warranty
Denny in Los Lunas is offline   Reply With Quote
Old 04-25-2012, 07:40 AM   #19
TURBS's Avatar
Imho it really doesn't matter how much you take it seems you still don't have what you need.
I take the basics and if that isn't enough then itll have to wait .
normally if I don't have it someone will.
Old 04-25-2012, 07:45 AM   #20
Herk7769's Avatar
So THAT is why everyone wants to camp next to me!
I thought it was my wit and charm.
Maybe I am half right...
