Old 07-29-2011, 10:12 AM   #1
Never own one again...Rockwood that is
After years of continual problem with our 2006 Rockwood 8280, I am moved to vent my frustration, and anger with the manufacturer and dealerships somewhere, for someone to read...hopefully to keep someone from make the same purchase mistake that we made. Our latest issue is the slide out not wanting to go out or come in normally. Its that latest in a long line of issues that I have had to resolve since we purchased the unit. In an effort to resolve the slide out issue I called the manufacturer and tried to get information about a larger motor that I read about for this unit on another forum that seemed to be the answer to my issues as well. Forest River rep emphatically stated that there was not a larger motor for the 8280. After some discussion, and trouble shooting questions, the rep stated that Rockwood didn't make the motor and that I would have to contact the manufacturer of the motor for more trouble shooting. Calling the manufacturer of the slide out motor resulted in an affirmation that not only was there a larger motor but it was well know that Rockwood used smaller motors on larger slide outs and that there was a history of issues like mine. I get the impression that in the RV industry that Rockwood is a lower end unit. Being a novice at the RV experience I can tell you that I have learned my lesson with respect to Forest River. But alas, you get what you pay for.... Other issues that we've experience with our Rockwood 8280 - Propane hoses and selection valve. Initially the 8280 came with an "automatic" selection valve. That valve and the hose for the port side propane tank did not work. Neither the dealer or purchase nor the manufacturer would replace the hose or valve. The dealer could even figure out the problem. Needless to say I had to purchase a replacement valve and hose. - Bolts that hold the axel to the frame on the port side we missing! After several months of owner ship, we were out and I had to crawl under the unit for some reason and I got to looking at the undercarriage and noticed that the bolts holding the frame to the axle assembly (2 each) on port side were missing. The remaining bolts we not torqued when I checked them. - The unit had electrical problem from the very first day. Our very first outing we pulled into a camp ground that had old power outlets and discovered that we could not power up the unit. The campers in the next space with powered up with no problem, so to trouble shoot we pulled in to their outlet and still not power. The next day we broke camp and drove three hours to the dealer only to have them tell us there was no problem with the camper. I pulled the exterior shore power receptacle and discovered that during assembly the white and black wires were inverted on the receptacle. (The plug clearing indicated a position for the white, black and red wires...white and black had been improperly installed). - Inverter (power panel) As a result of the above, we also discovered that there was a constant hum in the speakers of the 5th wheel. It was noticeably louder with the use of more electrical equipment. Replacing the inverter (power panel) eliminated the issue. Once again the cost was ours not the dealer or manufacturers. - A fastener in the step broke. Calls to the manufacturer could not help me find a fastener or any recommend fix. I finally had to turn to the mechanics on the hanger floor to find a special rivet that could be used to repair the stairs. I won't even go into the trim issues and the counter extension piece problems that we've had.... Can you see my frustration?!?
schmowie.liebowitz is offline   Reply With Quote
Old 07-29-2011, 10:46 AM   #2
Boyd's Avatar
I know the feeling~~Too soon old and too late smart. On the flip side, "It could have been worse."
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 07-29-2011, 11:44 AM   #3
Originally Posted by schmowie.liebowitz View Post
After years of continual problem with Can you see my frustration?!?
Oh by the way does this mean Rockwood & FR are the only makers of RV's that have problems? Trust that now you got to vent you feel better.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 07-29-2011, 04:28 PM   #4
hockeytownmom's Avatar
There's always a lemon in a product line.
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 07-29-2011, 05:25 PM   #5
The increase of quality of the auto manufacturers has not rubbed off on the R V manufacturers. After having my Flagstaff for over a year, I almost have it to the point where I wouldn't be ashamed to sell it. Wayne
wayne anthony is offline   Reply With Quote
Old 07-29-2011, 06:53 PM   #6
Timex's Avatar
I appreciate the confidence you have now instilled in me of my recent purchase of a Flagstaff V Lite! I think. Just remember, man has never made anything that will last forever. And lastly, if you are dissatified with your spouse, well, you picked them! So sit down and rest awhile. Have a cold drink!
Timex is offline   Reply With Quote
Old 07-29-2011, 07:52 PM   #7
Koodog's Avatar
Yep...I can tell you've reached a boiling point. Rest assured FR is not the only Rv mfg that has issues. I do agree you've had more than your share. In my opnion your PDI sucked. Most of this should have been caught prior to you driving it away.
I spent a great deal of time on my PDI and was assured that all things functioned properly before I signed on the dotted line.
Hang in there!
Walt-N-Terry Sanford
03 Dodge Ram 2500 Diesel
08 Rockwood 8317
Koodog is offline   Reply With Quote
Old 08-02-2011, 03:33 PM   #8
In reply to your replies...
I understand that there are issues with all types of equipment and that one manufacturer may have as many issues are any other - which is said. Someone posted that the RV industry needs establish the same quality control standards and manufacturing practices as the auto industry...and that is absolutely the case. If you read my original post you'll notice that small things we never caught from the assembly line - bolts not installed in the axel housing, wires cross installed, etc. There is a post in this forum where someone had a leak in their unit and discovered the pipes where not cemented together. For all of you that have a "oh well" attitude - these this just happen, would you tolerate the same from your car? Or you boat? or even your house? My issue is as much with quality control as it is with after the sale service. Ok, so in my case there was no service after the sale. The service industry within the RV industry is pitiful at best. As an aircraft engineer I have done most of the work to repair my 5th wheel - heck I had to the dealer couldn't. I had to figure out the electrical problem, they couldn't. I had to figure out why propane wasn't coming from the port side tank - the dealer couldn't. And FR - they didn't step to the plate at all. Their attitude was that if the dealer couldn't fix it there was not much there could do either. Thatís what most of my frustration is about Ė Sa-la-vie platitudes donít cut it either!
Thanks to some - others...well...never mind.
Old 08-02-2011, 04:06 PM   #9
mg0427's Avatar
Is this just a rant or do you really want people to pick this apart? I do have lots of questions related to this post, but will give you a chance to just rant for thats all it is.
The Family Truckster Team:
Michael & Belinda
mg0427 is offline   Reply With Quote
Old 08-02-2011, 06:41 PM   #10
Boyd's Avatar
Buyer beware!
Face it, we're a captive audience. We choose to play with expensive toys and unfortunately with that choice comes dealing with an industry, by all appearances, that caters more toward bottom line than quality control.
I've been self employed for the better part of 50 years and never, never would have thought anyone could put a product on the market as shabbily and ill engineered as some of RV's we hear about on this forum. To add, "and stay in business."
My Dad used to say, If you want to dance, you have to pay the fiddler.
Caveat emptor!
