Old 08-25-2017, 09:27 AM   #1
mini-me's Avatar
NEW 2507s
Just got our new 2507s home, a couple of questions we forgot to go through at dealer. Can't find the water pump and water filter on this one. Is it hidden behind one of the little panels inside? Is there a secret way to open one of those 3 hinged doors?
mini-me is offline   Reply With Quote
Old 08-25-2017, 09:44 AM   #2
Fulltime family RVer
They rattle when running.
I'd put water into the tank and run a faucet. You should be able to find it by following the noise.
Old 08-25-2017, 09:50 AM   #3
mini-me's Avatar
That's what we were thinking, just thought if anyone knew offhand
Old 08-25-2017, 11:34 AM   #4
Take the screws out of the third hinge to open the access panel.
stephndudb is offline   Reply With Quote
Old 08-25-2017, 12:53 PM   #5
mini-me's Avatar
found it, in the bathroom. Think we will keep that third hinge off and just add a knob and latch. Seems silly to have it screwed shut.
Old 09-01-2017, 08:49 PM   #6
LilyPad's Avatar
We just added catches to our water pump access in the bathroom and the water heater access in the pantry. No real need to add a knob unless you want to match the other doors. Eventually we will probably fill in the holes left from the removed hinge.
2018 Rockwood Mini Lite 2507S
2011 F150 5.0L SuperCrew
LilyPad is offline   Reply With Quote
Old 09-18-2018, 10:35 PM   #7
Aluna
My 2507s battery is not keeping charged. Does any one know what size the invetor is under the fridge?
Aluna954 is offline   Reply With Quote
Old 09-18-2018, 10:39 PM   #8
Aluna
Mini lite 2507s dry camp
We like to boon dock a lot. We do have a genarator but the batteries don't seem to keep a charge. We have two 12 volts. Anyone else have this problem?
Old 09-18-2018, 10:47 PM   #9
bikendan's Avatar
That is a CONverter, not an INverter.
Probably is a WFCO 55amp converter.
Do you have the battery disconnect switch engaged?
Equalizer WDH
Old 09-18-2018, 11:10 PM   #10
Aluna
Are you talking about switch outside the trailer by batteries. If so I do drive with switch on.
