Old 07-26-2011, 08:03 PM   #31
lindy's Avatar
Jacksum2; Ours had the 2 5/16" class 4 hitch
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 07-27-2011, 05:43 AM   #32
Hitch Size
Thanks a lot. I never knew until recently that there was anything larger than a 2" ball but I will get a 2 5/16.
Jack
jacksum2 is offline   Reply With Quote
Old 08-03-2011, 05:00 PM   #33
On our 2011 model 2604 when using the demand water sytem after sitting a couple of hours of not turning either the hot or cold water on the lines have air in them. Everything works fine when hooked up to city water. Any ideas as to what I am doing wrong.
dadcool is offline   Reply With Quote
Old 09-06-2011, 08:09 PM   #34
I see you solved your wheel chock problem. I have a 2012 2608ss which I think has the same axel setup as the 2604, and X Chocks fit between the wheels just fine. Anyone wanting this type of chock might want to check them out.
Adolphbell is offline   Reply With Quote
2604, utah
