Old 12-31-2013, 04:56 PM   #1
PhoneDude 8289's Avatar
New 8289WS Delivered
Took delivery on our brand new 2014 Rockwood 8289WS on 12/30/13. The pre delivery went great taking about four hours. Norman at Orlando RV did a great job during the pdi explaining everything and answering all our questions. The remote for the fireplace was missing but he went and found one for us.
After loading all our things in it we headed to a campground, Orange Blossom KOA. So far a pretty nice stay and no problems setting up. The only thing we haven't figured out is the tv. It works great over the air but can't get it to work on cable. The jack with the amp has nothing plugged into it, if I turn it off the light goes out and the ota signal is lost but no cable. Swaped the outside cable/sat connections and no difference. Guess I'll have to start taking things apart to see how it's wired at the back of that switch.
Other than the miner tv problem we love this unit.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 12-31-2013, 05:28 PM   #2
tomjsas's Avatar
You will most likely need to go into the tv and change the input setting from air/antenna to cable and the it should work. Remember to keep the amp turned off when on cable.
Tom - 2014 8289ws, 2011 Chevy 2500HD
Tom
Pull-Rite 16K Super 5th
2014 Rockwood Signature Ultra-Lite 8289WS
2011 Chevy 2500HD - DuraMax (Just over 5000 miles now!)
Nights camped in 2014 - 21
tomjsas is offline   Reply With Quote
Old 12-31-2013, 07:41 PM   #3
Congrats on your 2014 Rockwood 8289WS. Great way to start out the new year!
Old 12-31-2013, 07:59 PM   #4
NELA
Weezer's Avatar
Soooo wish we were camping this weekend. Haven't been out since Thanksgiving....
Congrats on the new toy!
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 01-03-2014, 05:15 PM   #5
Tried changing input settings on TV, no cable. What I did was take all jack loose checked cable colors to trace the cable. The amp jk was wired incorrectly. Every connection at the jack including the cable / sat jack at the outside were loose. Corrected all the loose connections and wiring at the amp. We now have OTA and cable channels and excellent reception.
Joe & Beverly
2014 8289WS lifted
Old 01-03-2014, 05:19 PM   #6
tomjsas's Avatar
Excellent! Too bad it wasn't as simple as changing the input on the TV
Tom
Old 01-03-2014, 06:52 PM   #7
Also found a situation behind the battery box and had to remove the battery and box to correct it. The terminations behind the box and at the battery disconnect switch were barely hand tight. One if the nuts on a stud was started and took several turns to tighten it. Guess I'll pull the breaker panel and check all those connections and anything else I can get into.
Joe & Beverly
2014 8289WS lifted
Old 01-03-2014, 06:59 PM   #8
tomjsas's Avatar
Something for me to check too. I've had issues at the beginning with bolts on the landing gear shaft shearing. Put sturdier replacement ones in and always carry extras now.
Tom
Old 01-03-2014, 08:55 PM   #9
Thumbs up
Thanks for the info, I'll have to be sure and add that to my list as soon as I check all the terminals in the breaker panel and converter.
Joe & Beverly
2014 8289WS lifted
Old 01-04-2014, 07:57 AM   #10
French's Avatar
Congrats on the the new rig. I am interested in how the tundra towed it. How did it work out. Any driving impressions?
Dave and Joanne
Southwestern Ontario
2016 Ford F250 Lariat crew cab 6.7 diesel
2015 Rockwood 8285IKWS Diamond
Jokes about German sausage are the wurst
French is offline   Reply With Quote
