Old 09-30-2012, 11:59 AM   #1
Lanningjw's Avatar
New Calmark cover for the Windjammer
The Calmark cover is on it way to live on our Windjammer over the winter. The TT will be living at the resort, it has lots of trees around it.
Any advise on covering the rain gutters with Tennis balls? what else should you cover so this 1K cover does not rip or tear?
https://lh6.googleusercontent.com/-a...0/DSC_0023.JPG
https://lh3.googleusercontent.com/-_...0/DSC_0078.JPG
2012 Windjammer 3001W
2010 Roo 19 (traded in)Mustang pop up (Sold)
1,000/10,000 equalizer
2000 Lund fishing Boat/2005 King Ouad 700 ATV
Windjammer lives at a Resort in Northern Minnesota. Lots of walleyes!
Lanningjw is offline   Reply With Quote
Old 09-30-2012, 05:30 PM   #2
Old car's Avatar
I have the Calmark for our Windjammer and used it last winter. Love it. It is heavy so I set it on top of the TT via a step ladder and then climbed on top using the TT ladder at the rear of the trailer. Don't forget to fold down your radio antenna before rolling out the cover. I put tennis balls on the down spouts and on the end of the cord that hooks to the tow vehicle. I also drilled holes in the battery box so it would drain in case anything got inside it. Battery was on a tender through the winter. A small bucket over the top of the electric tongue jack as well.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 10-01-2012, 10:26 AM   #3
Lanningjw's Avatar
Thanks man,
How did you go about getting the tennis balls to stick to the down spouts? I was think you cut a small slit in the ball and then slide it over the plastic spout? Will they stay on while your putting the cover on?
Did you cover the TV antenna? seems it would cause problems when your pulling the cover over it...
Old 10-01-2012, 11:13 AM   #4
Old car's Avatar
TV antenna folded down did not offer an obstruction. When I got my cover they way they had it folded I started at the front and rolled it out toward the back. Then I threw the sides over the edge and the wife would pull it out away from the trailer until the full length was down. This cleared the tennis balls (with a small slit like you said) and they stayed on. Once the entire trailer was drapped in the cover and you make sure your door entry is lined up--pull that drawstring as tight as you can to cut down on wind flap. Any of your roof obstructions--vents, A/C, etc.--just carefully work the cover over them and you should be fine.
I will be curious to see how it goes this year since I had to fold the cover up this past spring. Hopefully it is in format to go right on again this winter.
Randy and Patty
Old 10-01-2012, 11:44 AM   #5
campercher's Avatar
Question on winter covers what is the best way to keep foam strips on the sharp edges of a tt is tape a good way? if so what kind painters tape ? we are in wisconsin so we might get snow and cold this winter any suggestions ? Thanks Cher
campercher is offline   Reply With Quote
Old 10-02-2012, 02:34 PM   #6
What measurements did you use for them to make the cover. Would you change anything on the size you ordered on the 3008w
Rsbcool is offline   Reply With Quote
Old 10-02-2012, 03:02 PM   #7
Old car's Avatar
Make an inquiry with them on their website and they will send you a sample kit of material and strapping material used. It will have a little diagram for critical dimensions that they need and then I included a top view drawing I made up concerning the v-nose portion of the trailer. Not sure where I put my copy but I wouldn't change any of the dimensions I submitted. It fits very well and the draw string at the bottom will help cinch it tight and pulls the cover under the trailer a little bit.
Randy and Patty
Old 07-24-2015, 02:49 AM   #8
ElShamardo's Avatar
Did Calmer make a "V" front design for the Windjammer?
James & Kathi
Trailer: Rockwood 8299-BS 5th Wheel
Truck: Ford F250 4WD 6.7L King Ranch
Austin Texas - Live Music Capital of the World & Home of the Longhorns!
ElShamardo is offline   Reply With Quote
Old 07-24-2015, 05:02 AM   #9
Old car's Avatar
Do you mean CalMark? That is the cover I bought. It was custom made for my Windjammer (at the time). I no longer have my v-nose but the cover was given to a fellow Jammer owner who had the same model trailer.
Randy and Patty
