Old 11-22-2015, 07:38 AM   #1
New mid year 2016 8289WS changes - D range tires and center island
We just picked up our new 8289 that had a late October build date. Spending the first weekend at a campground a few miles from the dealer. 36 degrees this morning
Rockwood has changed their center island. The prior island with the doors on the fireplace side was the one item my wife didn't like. The new one is similar to that in the new 8289. We really like it and find the convenience much better. Perfect spot for the trash can and all the stuff we keep under the sink at home. We heard from Rockwood that customers were asking for the change and they had been considering doing it. Nice improvement that will be a hit in the marketplace.
The other big change is that D range tires are now standard. Still a mystery Chinese brand but D rated nonetheless.
Actual weight came in at 8380 lbs with a single 15K A/C.
One question. Our Keurig machine only flashes instead of working. Same story for a heating pad. A high draw blow dryer works fine in the same outlets. We are hooked to electricity at a campground. Does this sound like quality of supply from the campground or an issue with the new trailer? Click image for larger version
Name:	ImageUploadedByForest River Forums1448199470.897845.jpg
ID:	94778Click image for larger version
Name:	ImageUploadedByForest River Forums1448199496.154215.jpg
Major kudos to Rockwood for listening to their customers. Impressed so far.
woodguy00 is offline   Reply With Quote
Old 11-22-2015, 01:30 PM   #2
I'm guessing your Keurig is bad. Try plugging it directly into the camp power pedestal and see what happens.
Look up where your tires were made here:
Tire DOT Plant Codes ? Sorted by Plant Code - Tire Safety Group
You may find they were not made in China (mine were made in France). The first 2 characters of the tire ID # are the plant code.
2011 Traverse LT, 3.6L, FWD
Old 11-22-2015, 03:31 PM   #3
WFD
Nice island and seems much more useful...I better not show the DW, she will want to trade ours in!
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 11-22-2015, 05:18 PM   #4
Tires are CastleRock ST D rated by Lionshead and say ' Made in China'. 2540 lbs per tire weight rating at 65 lbs.
I tried the heating pad and the Keurig at the shower house here and neither worked. I'm getting about 113-114 volts in the plugs so I don't think it is a problem with the trailer electrical. Thank God there is a McD's about two miles away for morning coffee.
Old 11-22-2015, 05:23 PM   #5
Get one of these:
Mr. Coffee¬ģ Simple Brew 4-Cup Switch Coffee Maker White, TF4-NP
Cheap and almost indestructible. (And greener, too, if you're into that.)
Old 11-22-2015, 05:28 PM   #6
Pickin' & Campin'
Woodguy00, we very recently took delivery of a 8529IKBS that has the same kitchen island. It is a super design improvement over the older island! Those under island LED ambient lights are perfect for leaving on after you hit the sack. Just enough light to see the steps in the middle of the night.
Enjoy your new rig!
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 11-22-2015, 06:47 PM   #7
5Picker,
Where do you turn on those lights? I don't think we have them but perhaps we just don't know how bad to turn them on!
Old 11-23-2015, 09:41 AM   #8
Pickin' & Campin'
Ours turn on by a switch located on the wall where your microwave is located.
The wall/cabinets in ours is slightly different so maybe yours doesn't have them or the switch is somewhere else?
Look up under the metal base between the fridge and the island (below the island cabinet doors)... ours has an LED strip light attached up under the full length of the base.
Look at the attached photo. While it was daylight and the entry door was open,
the light was actually on and you can see the illumination on the left lower side.
Old 11-23-2015, 09:48 AM   #9
Pickin' & Campin'
Our switch is with two other switches on the right hand side of the wall.
Look directly above the island faucet in the photo, it's the brown/black box closest the top of the three. (switches - USB charge outlet - 110v outlet)
I realize your wall is different but maybe you have the same switch/outlet combo somewhere?
Old 11-23-2015, 02:11 PM   #10
I really like your unit. My wife and I have a Rockwook 2013 8289ws Diamond Package. Even though our islands are similar I like yours better. Our island also doesn't have the doors on the the entertainment system side. We have something we like that you don't have to the right as you walk into the unit before the staircase to the bedroom. We have cabinetry that is similar to a larder and on the backside you have more storage for towels or bedding. We love our unit! We wish you great camping and wonderful memories.
Bears1985 is offline   Reply With Quote
tire, tires
