Old 05-01-2016, 12:11 AM   #1
New owner
Hi. I picked up a 2011windjammer 3006w 3 weeks ago. We are getting ready for test trip. Question?. How do I know how much propane i have left. Do i have to remove tanks from v nose to fill them. TIA.
sylphil is offline   Reply With Quote
Old 05-01-2016, 12:27 AM   #2
I go RV'ing not Camping
jgourlie's Avatar
Only way I know how to check how much propane is left is to pick up the cylinder and feel the weight. You have to remove them to fill them. It's a good policy to fill them before each trip just in case
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 05-01-2016, 01:03 AM   #3
Moderators' Assistant
bikendan's Avatar
You don't have to remove them.
I've often had mine filled by just pulling the trailer to the station's big tank and they use a hose to fill both of them.
Also the RV parts store.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 05-01-2016, 08:43 AM   #4
Try one of these: Dometic LPGC10 LP Gas Checker: Automotive
1988 Coleman Sequoia - popup (1987-2007)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
Old 05-01-2016, 09:51 AM   #5
raspivey's Avatar
You can also use a bathroom scale. There will be an empty weight stamped on the tank, usually at the top somewhere. Bottles are usually either 20 lb or 30 lb capacity. Subtract the empty weight and it should give you an approximate.
2012 Chevy Tahoe LTZ - HD tow package
Old 05-01-2016, 10:08 AM   #6
gectisme's Avatar
Congrats on your WJ! Great model choice.
You can check using hot water, if your WJ tanks are like mine you should be able to do it without removing them.
Below is a link to a you tube video on how to do it:
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags.
Equalizer E4 1.4k/14k WD Hitch.
Furrion FOS48TA Observation Camera
Garmin RV-760 GPS
gectisme is offline   Reply With Quote
Old 05-01-2016, 02:00 PM   #7
Thank you for responses. The trailer is 35 ft long. I need to know how do I remove the tanks. They are 30 lb each. And enclosed in the v nose. There is a bracket holding them and 2 hoses attached. There is a knob in front of each tank . How do we disconnect them ?. There is no manual. Thank you
