Old 02-24-2016, 06:26 PM   #11
Originally Posted by gectisme View Post
We have a WJ3006 and really like it. Only been out on 3 trips so far and we have a Equalizer E4 10k/1k, which is what the dealer recommended. Now that I know more, I would have insisted on a 12k/1.2k but having written that, I have no sway issues at all so far with my 3/4 Ton Dodge. The one thing with the Equalizer, it is pretty noisy especially when moving slowly around looking for your campsite. I am just hoping I don't pull into a camp late at night and disturb all the other campers...
Good luck with your decision, IMO, you can't go wrong with a WJ and especially the 3006 if you want a bunkhouse.
Try these:
https://www.etrailer.com/Accessories...5-01-5150.html
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 02-24-2016, 07:27 PM   #12
gectisme's Avatar
Originally Posted by rockfordroo View Post
Thank you, just ordered them!
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper). Equalizer E4 1.4k/14k WD Hitch. TST 507 TPMS. Furrion FOS48TA Observation Camera. Garmin RV-760 GPS. Honda 2000i Genny, PI EMS-PT30C.
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 02-24-2016, 08:44 PM   #13
Pyromedic's Avatar
Thanks everyone for the tips. I think I'll be ordering the Equalizer 1400 with the plastic jackets to prevent the metal on metal squeaking.
Pyromedic is offline   Reply With Quote
Old 02-25-2016, 06:41 AM   #14
My friend did alot of research and finally bought the Reese Dual Cam Sway and he said it works great.....
Save a beer for me!!! Happy Trails....Be Safe....
sunnyinfla is offline   Reply With Quote
Old 02-25-2016, 07:29 AM   #15
wicked1's Avatar
Originally Posted by Pyromedic View Post
I'm waiting for the Windjammer 3006 to show up at the dealer to take a look at it. If we like it we will be purchasing it. I currently tow a 10 year old 31 foot flagstaff with a weight distribution hitch. I'm wondering if I should purchase a new WDH or try to use my old one. I'm sure technology has improved in the past 10 years with bars and chains. I'm thinking of ordering the equalizer WDH 12,000 or 14,000. The hitch weight of the Windjammer is 990lbs with an unloaded weight of 7550lbs.
Look at the Anderson there is no noise, no bars, simple setup, quite and you can back right in without having to remove away control on some other WDH. I used the Camco EZ-Lift 1000/10000 at first but storing the bars was a pain and the Hitch was heavy.
https://www.andersenhitches.com
Good Luck
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 02-25-2016, 08:03 AM   #16
When you pull into the campgrounds swing your bars around and then proceed to your campsite with the WD disengaged. No noise, only takes a minute, and it's one less step to do when you are at the site anyway.
Old 02-25-2016, 08:26 AM   #17
D_B Travelers's Avatar
I purchased the bracket jackets and they helped eliminate the metal on metal noise when working in tight camp spaces. I also will loosen the socket bolts if sharp maneuvering is needed, which will make it easier to turn and lessens the noise. Yes, I keep my sockets greased per the instructions, but I also run them torqued to 80 ft/lb instead of the 45 that the instructions say. I found it helps in windy situations out on the road to increase the torque.
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 Ė 1996)
D_B Travelers is offline   Reply With Quote
Old 02-29-2016, 06:25 AM   #18
MCTroy
We have aWJ 3029 and it tows fine behind our 3/4 ton Ram. We added a sway bar as added control really just because we already had it. Our hitch is an old Reese and we think it is only 1000#. I don't overload the front storage on the WJ and we are level when towing. No problems going over NC mountains last year. Should we upgrade because this hitch is old? How can I tell if it is 1000# or 1200#? The hitch was given to us over 10 years ago...
2015 Windjammer 3029 Diamond Edition
2011 Ram 5.7 hemi
Ohio River Rat
Hurry Spring 2018! We have plans ready!
MCTroy is offline   Reply With Quote
Old 02-29-2016, 06:53 AM   #19
If you go with another hitch because of Age give me your Old one because we are still using the OLD Reese DC 1200# that my FIL gave us that He bought in the 60"s! I also have the 500# and 750# Bars that fit the Same head! All three # numbers are on a decal from the Factory,but there is also a Noticeable difference in size and Taper of the 3 sets! I am sure yours are Newer style as ours have the bolt on Cam detent's! I had a heak of a time setting up our V-Lite brfore I figured out there were 2 Issues 1 was the Crappy OE Tires,fixed with 8008 Maxxis and the REAR FWT that F/R knew was a Problem and Moved them to the Front the Next year! Ours is still in the Rear,and we travel with Minimal F/W in tank! Youroo!!
Old 02-29-2016, 08:24 AM   #20
MCTroy, the age really doesn't matter if the hitch is in good shape. If it has no cracks or bends or visible excessive wear then you are probably (note disclaimer ) fine. However, you didn't say if you had weighed the rig at the CAT scales to see what your hitch weight actually is. Might be good to know even if you have been towing for a while with no issues. Our WJ was supposed to have a 880# hitch weight when new, but it was actually 1075# on way home from the dealer. You can read in this forum, in many places, that the dealer doesn't know/care what hitch they sell you with the rig, only that you get off their lot with it successfully. I am sure it is not true for all dealers, but from the comments it looks like a majority. We upgraded our 1000# hitch to a 1400# hitch and it does handle even better. The factory specified pin or hitch weights are the least that particular towable will ever weigh, without any optional equipment, propane in the tanks, battery, extra A/C units, fluids in the tanks, and all the gear we pack. It is not a real world number, ever. Only a starting minimum weight. I take the GVWR for the trailer and, if it is a TT, multiply that number by 15% (ideal is about 12%) to get a hitch weight number; then I would purchase the hitch using that. As long as you didn't exceed the GVWR for the trailer and you balanced the load properly your hitch would be fine. Same for 5th wheels, but I use 25% as the multiplier even when the ideal is 22%. You just need to know the actual weight on a good CAT scale first.
windjammer
