Old 08-15-2010, 09:06 PM   #1
Arn
Arn
New problem every trip is getting frustrating...
2010 2604 is great but is becoming a pain. Pilot light on stove didn't work, shower stall leaked, water pump switch light quit working, kitchen faucet dripped, etc, etc. Nothing major, nothing that is Rockwood's fault but it all adds up to a lot of inconvenience & frustration. Dealer has been great but it's over an hours haul & $20 of fuel to get there every time. Now my toilet leaks. It is at the top just before the flush valve & seems to leak when forward pressure is put on the toilet. Is there anything in there that I can tighten or replace or are these things a one piece unit?
Arn is offline   Reply With Quote
Old 08-15-2010, 09:20 PM   #2
Boyd's Avatar
Mine had the same problem except it only leaked when the hot water heater was on. After mopping the floor many times, I narrowed it to one thing, "heated water caused pressure in the lines and the achilles was at the toilet connection." The fix was an easy one and I hope you are so gifted. The plastic nut that holds the line to the toilet (the one impossible to see without a mirror) needed tightening. Good luck.
Boyd is offline   Reply With Quote
Old 08-15-2010, 09:25 PM   #3
Arn
Arn
Thanks. Out comes the old swiveling extension mirror.
Old 08-15-2010, 10:11 PM   #4
grhodes50's Avatar
I know it's hard but hang in there. I usually have 3 or 4 problems each time I camp and I've had my trailer for 19 months now. It's been in the shop about 4 of those months. Some I can fix and some have to go back to the dealer for repair.
The last time I had a bearing going out in the AC so I made a list of everything I could find wrong. Ended up with 14 items, some very minor but if I was going to have to take it in, might as well have them fixed as well. All under warranty. This was only the second time out in the tt after getting both sidewalls replaced because of delamination.
Very frustrating. My wife and I are currently looking at new trailers.
Good Luck!
Gary & Trish
2018 Nights Camped - 5
Old 08-15-2010, 10:18 PM   #5
Carry a small assortment of tools and fix things when you see them. Remember this is not a stick house, this is a mobile home. Things come apart going down the road. It happens to everyone. Either learn to be a good jack of all trades and fix them yourself or be prepared to pay a lot of money to repair shops for as long as you own an RV. That is just a fact of life.
Old 08-16-2010, 03:14 PM   #6
Arn
Arn
I do carry tools. I do repairs. I know these things rattle & shake. Point was, I'm tired of going back to the dealer to get him to do his job under warranty. Point was, I did repairs on all previous trailers & plan on doing them on this one too, once the warranty expires.
Old 08-16-2010, 03:28 PM   #7
It sure does make one wonder about the quality of these new units. Before I ordered my new Flagstaff, I had a 1995 Cobra Sunrise, and simply never had any problems with it. But it was a very expensive 5er at the time, and they did go out of business, probably spent too much building them!
Old 08-21-2010, 08:17 AM   #8
MissouriCamper's Avatar
lucky
I work construction and use our 2006 Rockwood 2603 when I'm out of town on jobs plus when my wife and I go on vacations. Needless to say it has been well used. We've been extremely fortunate with this camper with the only problem being a small leak that developed last year and was solved by resealing the roof. As many miles as we have put on it it really amazes me that more hasn't gone wrong. PS- Will knock on wood that our good luck continues.
MissouriCamper is online now   Reply With Quote
Old 08-21-2010, 09:20 AM   #9
grhodes50's Avatar
That's great. I believe that there are way more trailers like your's than the ones like the OP's or mine. It just seems like either you get a good one or you get a really bad one. Not much in-between. I call it the plane crash syndrome. It doesn't happen very often, but when it does....
Gary & Trish
Old 09-06-2010, 08:13 PM   #10
Arn
Arn
Just back from another long weekend, more problems. Black tank valve leaks AGAIN, front hitch light quit working & a shelf in the lower cupboard fell apart. Rockwood brags about glued & screwed cabinets. The only thing screwed here is me because this cupboard was held together with staples. I've grown very tired of being nice when I call the dealer. I sure hope somebody piddles in my Corn Flakes tomorrow so I can take it out on the dealer. Why do they build trailers on Mondays & Fridays?
rockwood
