Old 07-21-2016, 03:08 PM   #11
unless you firmly GLUE down the membrane the top will lift in the area just back of the front cap due to airflow over that area causing a vacuum above the membrane.
Ever see an old car with a vinyl top going down the road with its roof blown up in the air.
If they cant pull the old top tight , how will they pull the new one.
Just peel back the rubber apply the glue and roll with a linoleum roller. a couple wrinkles wont hurt and wont be seen up there. Much better than $9000.
hillsdaletc is offline   Reply With Quote
Old 07-21-2016, 03:15 PM   #12
ReRoofing sticker shock
Following a much to close of an encounter with an oak tree, my 32 ft. Flagstaff needed a new roof. Although the new roof was $7,000, the cost (less a deductible) was covered by insurance.
Good luck with your roof repairs and may the rain that falls during your travels remain outside your rig.
bobkathy78759 is offline   Reply With Quote
Old 07-21-2016, 04:41 PM   #13
I have the same trailer. 8289WS, 2011. I noticed when I took delivery that it had a few wrinkles in the roof material. I assume that was normal and didn't worry about it. After a few years I had other travelers tell me that I was getting huge bubbles in the roof. I took it back to the dealer and was told it was from a few small holes in the fabric along one edge. They patched those holes but it did not help. I still get the bubbles. I have tried a band aid approach of attaching aluminum straps across the roof with screws to hold the fabric in place. This was suggested by the dealer. This didn't help either as the fabric would just work the screws out and the aluminum straps would come loose. Attempts at getting help from FR was useless. I was told by my dealer that some of the trailers are made with only edge gluing. I doubt that this is true as you could never hold down a roof by gluing at edge only. I suspect it is more likely that the factory had some issues with bonding this Alpha fabric down and is working hard at not redoing the roofs that some customers were unlucky enough to acquire. Not sure what I am going to do next. Hard to justify $9000 on a $35000 rig.
dan.beilman is offline   Reply With Quote
Old 07-21-2016, 05:22 PM   #14
CaptnJohn's Avatar
I was on Hwy 9 in SC and saw a CUB with the roof membrane flopping ~~ no way to contact him as we were in opposite directions... he probably is unaware..
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 07-21-2016, 05:46 PM   #15
Originally Posted by gspot01 View Post
Imo, completely normal price from a dealer. I just picked mine up two days ago from the dealer for the exact same issue. I was told it would be an $8k repair. Luckily mine was still under warranty however because I just bought it in April. The dealer tried to squeeze FR for a whole new roof, but FR wouldn't go for it and made the dealer peel back the front few feet and reglue it.
Sent from my SM-T320 using Tapatalk
Are you saying they charged you $8K to pell back a few feet and re-glue it..
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 07-21-2016, 07:44 PM   #16
Weekender
Ford1's Avatar
Two years ago I had the rubber roof on my previous Georgetown replaced by Coastal RV in Cocoa, FL. They replaced the old roof with a new PVC roof at a cost of $4600.00. They did an excellent job and the PVC always cleaned up much easier compared to the older EPDM. I would use them again if I needed another. CW wanted almost $6000 to install new EPDM.
Ford1 is offline   Reply With Quote
Old 07-21-2016, 07:50 PM   #17
CaptnJohn's Avatar
There is an ad in TL of a company that has a 3 day process that states the last roof ever needed. At their shop or come to you. Wondered about the process.
2016 F350 diesel
Old 07-21-2016, 07:52 PM   #18
Broadway Joe's Avatar
Originally Posted by D_B Travelers View Post
While camping this past weekend, I got on top of our Wind Jammer roof to set up the satellite and noticed the front roof looked bubbled up. Upon closer inspection, I could see where the roof seal at the front cap had a crack about 6 inches long in the Dicor; however it wasn't loose. Apparently when driving the wind deflecting up over the front causes a low pressure area and the roof bubbles up because it has the ability to suck in air at the crack. It looks like the roof material is stretched and I am considering trying to fix this myself by removing the side trim and regluing the material. I have a full covered storage stall so I can do this repair without being in the Texas sun. I have not taken it to have it looked at and not sure the insurance will cover it as it isn't damaged, just had a seam crack open. I think it is the EDPM material.
You might try Texas RV Guys 1128 Blue Mound Rd in Haslet
Joe
2015 Wildwood 27RKSS
2015 Silverado 2500HD Duramax
Broadway Joe is offline   Reply With Quote
Old 07-21-2016, 09:02 PM   #19
Yes , this is a normal price. Very expensive to replace. Speaking from experience with exact trailer you mentioned.
Mike Tav is offline   Reply With Quote
Old 07-22-2016, 12:12 AM   #20
No, 8k was for a whole new roof. That's why the Forest River warranty division wouldn't approve it. They told the dealer they would only pay to have it reglued.
Sent from my SD4930UR using Tapatalk
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
roo, roof
