a very common topic on this forum. lots of talk about different defusers and things you can do to help and lots of talk about crushed and blocked heat runs.
Welcome to FROG from SoCal! Check your air lines looking for leaks, bad connections or crushed lines. Since they are working I would suspect a leak of the drop off is more than should be expected at the end of a run.
