Old 06-10-2016, 07:07 PM   #1
New to this RV thing. Gotta question.
We just bought a new 2015 3008w. As of 1 July we will have sold our house and we will be full time RV for a time. I am trying to familiarize myself as best I can before that date. I got a lot of good info off the site so far but in my search for the hot water heater (found it and the third hinge) I noticed some kind of rectangular box directly underneath the hot water tank. It appears to have no connection to the hot water tank but it does have a LP connection. It is on the floor next to the sub woofer and I found it when I pulled off the vent on the bar stool side of the counter. Any help would be appreciated.
sct5024 is offline   Reply With Quote
Old 06-10-2016, 07:13 PM   #2
Furnace?????
bruceatlam is offline   Reply With Quote
Old 06-10-2016, 08:13 PM   #3
ID:	110762 Here is a somewhat blurry picture... I hope.
Old 06-10-2016, 08:22 PM   #4
Looks like furnace. Is there ducts running out from it?
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 06-10-2016, 08:36 PM   #5
Heat ducks go down,can't see from vent area! Youroo!!
Old 06-10-2016, 08:42 PM   #6
Mine go out on sides. And run across floor under cabinets and shower and vent from wall.
2005 Honda VTX 1300
Old 06-10-2016, 08:45 PM   #7
RSchleder's Avatar
If it is the furnace it will have a panel on the outside of the RV directly behind it. One easy way to find out sure is to set the heat up and turn the furnace on--no doubt your answer to "is it my furnace to not" will come quickly!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 06-11-2016, 07:23 AM   #8
There is no access on the side of the trailer. It is right behind the front door and the only thing near it is the water heater access.
Old 06-11-2016, 07:54 AM   #9
Flybob's Avatar
Looking at the TT online, it appears to be the furnace. On the outside, I can see the WH access panel and just in front of it, I see the intake and exhaust vent for a furnace. There is no outside access to the furnace.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-11-2016, 07:59 AM   #10
Yes, furnace it is. I wasn't thinking the vent would be ducted further up. I was just looking at the side where it sat. Thanks all.
Old 06-11-2016, 12:11 PM   #11
A general suggestion for before you hit the road full-time. Take a couple of shake-down trips. They don't have to be too far, but stay at a couple of different campgrounds. There will always be more questions that come up, and fellow RVers at campgrounds will be happy to help and advise. Experience is the best teacher. RVs are complex machines and they don't always get delivered in perfect shape. The best way to be sure everything is working properly is to take it on the road before you start full-timing and make sure you try all the systems. That way, if you need to get some initial warrantee work done you won't have to stay in a motel while it's underway. Lastly, no matter how well you plan, I guarantee you will need stuff you didn't bring with you and most likely will bring stuff you don't really need. Full-timing is a major undertaking and bad experiences right out of the gate on your odyssey can ruin it for you. Shake down trips will help assure that you will get the most out of what can be an exciting and challenging adventure.
DrLewie is offline   Reply With Quote
Old 06-11-2016, 12:29 PM   #12
Flybob's Avatar
Make sure you have a pen and paper to make a list of the "Gee I wish we brought that" things.
TST Tire Monitors
2 100W solar panels
Old 06-11-2016, 11:43 PM   #13
Casino Camper
jughrad's Avatar
That appears to be the self destruct device. You push the big red button right after your first black tank disaster!
2016 Cherokee 264L (Rear Living)
2013 GMC Sierra Denali
jughrad is offline   Reply With Quote
Old 06-13-2016, 09:00 AM   #14
The OP was asking about a "Rockwood 3008 Wind jammer" the Furnace Ducts are in the floor they are supplied from the bottom fed plenum chamber in the 3008 unit! Youroo!!
Old 06-13-2016, 09:25 AM   #15
I believe the question was what is this. And it was the furnace.
2005 Honda VTX 1300
Old 06-24-2016, 04:46 AM   #16
RangeMaggotBob's Avatar
At least you found your subwoofer. I'm still looking for mine.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
RangeMaggotBob is offline   Reply With Quote
