Old 05-22-2013, 07:42 AM   #51
TURBS's Avatar
Imo the ground should be hooked to the battery ........
Old 05-22-2013, 07:42 AM   #52
KyDan's Avatar
My guess is the EB switch box melted simply due to corrosion inside the
box. There are just 2 simple contacts inside there that are separated by
the plastic pin. Pull the pin and the contact are -supposed- to come together
and send 12v to the trailer brakes.
These EB switches are cheaply made and NOT water proof. A little road
grime, salt, water & age all add up to a poor connection when/if
the pin is pulled.
A weak connection (corroded contacts) can overheat and eventually melt
the EB box.
If you are in a highway trailer disconnect event, you don't care if the EB
switch box is melting as long as the trailer brakes are ON.
I also wonder if the electric brake coils were over heated.
They should be checked I think.....
I've heard other folks who thought they could use the EB switch as a
parking brake. IMO there should be a red cardboard tag attached to
each EB cable on new trailers that says what it is for and what it's NOT
for.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 05-22-2013, 07:43 AM   #53
KyDan's Avatar
Yes but the other end has to connect to the trailer frame.
In this case they have apparently used the EB switch mounting screw
for this.
Old 05-22-2013, 07:46 AM   #54
Herk7769's Avatar
Originally Posted by youroo View Post
Yes that is what I am talking about,the way the switch is mounted! OC says it has to pivot,the OP pics show the main (Ground Wire) on the same Sheet metal screw. It must be (Tight) to ground to the frame.Thus (NO) pivot. I said nothing about the groud for the (Brakes)? Youroo!!
Holy Cow! How did I miss that!
Talk about "finding a convenient ground!" You are so right.
"Woodie" strikes again.
My apologies.
HAM CALLSIGN - KC3FFW
Old 05-22-2013, 07:46 AM   #55
The switch is mounted and secured by a Self tapping sheet metal screw. If all of the ones you have owned are just like this one you better look agin at this Shoddy Mount. The (Ground Strap is held on by the sheet metal screw). A ground strap needs to be TIGHT to the frame for a good ground! I stand by my statement (Shoddy install)! Youroo!!
Didn't say anything about the ground wire in the picture which is, as you say, wrong and should not be on that screw. The ground has nothing to do with the EB switch.
Old 05-22-2013, 07:56 AM   #56
Herk7769's Avatar
Originally Posted by KyDan View Post
I've heard other folks who thought they could use the EB switch as a parking brake. IMO there should be a red cardboard tag attached to each EB cable on new trailers that says what it is for and what it's NOT for.
Sort of like "Coffee is hot" on cups and Warnings on gun barrels?
ID:	31110   Click image for larger version
ID:	31111   Click image for larger version
Old 05-22-2013, 08:09 AM   #57
Nice ear plugs being used by the guy on the right. All he has to do to increase sound suppression is pull the trigger.
Old 05-22-2013, 08:22 AM   #58
Herk7769's Avatar
Note his hat... So much for "Don't try this at home; we are trained individuals."
Old 05-22-2013, 08:28 AM   #59
Was probably trained by the head honcho or his boss.
Old 05-22-2013, 08:30 AM   #60
Arefbee's Avatar
Maybe he had already made it to the training on the first two initials that day.
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
brake control, brake wiring, breakaway
