Old 05-09-2016, 07:23 PM   #1
New trailer, toilet bad odor
New trailer, have been traveling with trailer for 3 weeks, have dumped toilet about 6 times, put hose on built in sprayer to clean. Today when dumping in chemical and gallon of water, we got terrible smell from toilet , I know it is a toilet with black tank but this never happened in our old trailer. Also the gage always show 3/4 full, I know this happens but would sure like to sole the odor problem. Thanks.
Jim and Silene
2017 Rockwood 2906WS
2014 Dodge Ram 1500 Hemi 5.7
Firestone Airlift 1000, Equalizer Hitch
Augustpilot is offline   Reply With Quote
Old 05-09-2016, 07:57 PM   #2
crunchman12001's Avatar
I found this product for the black tank treatment. This is the best I have used ( I used to use the pouches, liquids). I let the tank sit for 2 weeks with stuff in it and still had no odor. Give it a try. It cost a little more but I am sold.
Amazon.com: Happy Campers Organic RV Holding Tank Treatment - small jar, 18 treatments for RV, Marine, Camping, Portable Toilets: Automotive
2015 F-250 FX4
crunchman12001 is online now   Reply With Quote
Old 05-09-2016, 08:17 PM   #3
caper's Avatar
Is the black tank flush working properly? If you are flushing the black tank after each dump your gauges should have proper readings and there should be no smell from a new tank. We use the GEO method for odor control in the black tank.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 05-09-2016, 08:22 PM   #4
Bluepill's Avatar
Being a new unit, there may be a faulty connection to the vent stack or the toilet.
2008 Itasca Meridian 37H
Old 05-10-2016, 11:13 AM   #5
Our toilet was replaced free of charge due to an issue with the toilet allowing black tank smells passed the toilet.
Maybe look into that issue too
Curry's
2014 ROO 24 IKSS
2012 F150 Quad Cab Eco Boost short bed w/tow package
fyrdad is offline   Reply With Quote
Old 05-10-2016, 11:19 AM   #6
I would check the vent stack first. It should be venting the smells out of the rv.
Patrick & Cecilia
2012 GMC Sierra 2500 HD Crewcab Duramax
2014 Forest River Tracer 2750 RBS
Honda eu3000 Generator
2015 Nights Camped : 37
2014 Nights Camped : 33
Quasipato is offline   Reply With Quote
Old 05-10-2016, 11:20 AM   #7
karrun's Avatar
Yeah, I don't think you should have a bad smell on a new unit. I'd suspect something with the vent or plumbing.
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
karrun is offline   Reply With Quote
Old 05-10-2016, 12:27 PM   #8
Toilet smell
Just a thought , make sure that bathroom vent fan is not on as it will pull the stink up out of the toilet as soon as you hit the flush and open it. I think if you had a vent problem, when you went to dump it would not dump normal. I mean it would run out slower than normal. If your toilet drops straight into tank open it up , hold nose, look inside and stick tank if possible to make sure it really is empty. Good luck please let us know the outcome.
rickkey2 is offline   Reply With Quote
Old 05-10-2016, 12:41 PM   #9
Restcure's Avatar
+1 on the Geo Method.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 05-10-2016, 12:42 PM   #10
Weekender
Ford1's Avatar
I had the same problem at the beginning of last season. I ended up removing the toilet and found that the closet flange gasket was pinched, thus allowing odors to come into the coach. I cleaned everything up sealed all possible areas that fumes could escape through, installed a new flange gasket and it solved the problem. DW has an extremely sensitive olfactory system and she is now happy.
Ford1 is offline   Reply With Quote
trailer
