Old 03-21-2011, 06:21 PM   #1
Newbie question about 2304 and winter camping
I am looking for my first RV and the 2304 (or 2304S) is on my short list. Would I be able to camp in Ohio during the winter provided I am at a campsite with electric? Average winter temps are in the 20's but can dip lower (0-15) for short periods of time.
I know these are not technically for winter, but it seems to have almost the same insulation (R14 roof, R12 floor, R7 walls) as the arctic fox (R18/R7/R7) which everyone says is four seasons. The 2304's can also have the enclosed and elec. heated belly.
jam937 is offline   Reply With Quote
Old 03-21-2011, 06:35 PM   #2
(Kim)
Labzy's Avatar
Hmmm....I'm a newbie also lol, but I'm from ontario so we get a lot colder up here.
I think you still need to insulate the windows etc.. and look into what kind of heating they have for the tanks, because I know there are different ways to do it.
I think you also need to have a reliable gas detector since you are gonna have the furnace and/or heaters running. Also humidity would be a problem so look into ways to get the moist air out.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 03-21-2011, 06:41 PM   #3
From what the dealers have told me .... the furnace runs off the 110 when connected to land power and not the propane. The holding tanks are also heated by 110 when connected.
Again, this is what I've been told by salespeople
Old 03-21-2011, 07:06 PM   #4
sherdep's Avatar
I have a 2011 2306 and would be the same as the 2304 as far as options
I would have to verify this but according to the book that came with my 2306 - the heated option is made by Therma Heat (2 year warranty) and it turn itself on at 45 degrees and turns itself off at 67 degrees. The book shows diffrent heat pads that run off of 110 and 13.5vdc so when I get a chance I will look at my trailer and see if they are both voltages or not and post back
another option is if you get the storm windows - beware that they cover the whole window with a plexy glass and make then inoperable except the emergency exit.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 03-21-2011, 07:54 PM   #5
bikendan's Avatar
that's another salesperson's truth bender! the furnace does NOT run on 110v. the fan and electronics run on 12v but the heat comes from propane.
most of us use ceramic heaters when there are electric hookups, to save propane.
if you order heated holding tanks, they do require 110v AC power.
Old 03-21-2011, 08:01 PM   #6
sherdep's Avatar
and or you can add the optional Heater element in your A/C unit as well like I did to help heat the inside - was almost as cheap as buying one of the ceramic heaters and very easy to install and will also help save on propane costs as well
am thinking you would probably have to have a few space heaters in real cold weather but atleast you arent wasting your gas and using the electricity from the campsite
Old 03-21-2011, 08:09 PM   #7
(Kim)
Labzy's Avatar
Look into portable ceramic heaters, and get an extra gas detector. A friend of ours rented Rvs to tailgate, and all 4 men from one of the trailers died because the gas detectors had dead batteries. I'm sure things have changed in 10 years but still be careful whenever you are running propane while u are sleeping.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 03-21-2011, 08:27 PM   #8
sherdep's Avatar
the Gas detectors are now hard wired and have a LED indicator to tell you when it is working - it also has a test button - they are made by Safe T alert Model # 35-742 or atleast that is what is in my TT
Old 03-21-2011, 09:12 PM   #9
(Kim)
Labzy's Avatar
not good enough ...... ;p I doubt if I will ever use the propane while im sleeping, I'll get a portable heater for nightime. Call me paranoid.
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 03-21-2011, 09:45 PM   #10
So would the tank heating pads keep the tanks from freezing as long as I had power?
I could use 1 or 2 ceramic heater inside to keep warm that's not a problem. I'm mostly concerned with the tanks freezing
