Old 09-21-2010, 12:47 AM   #1
Newbie to Fifth Wheel
Hi,
I am considering purchasing a Rockwood 8265 fiver and I need some advice. I intend to tow with a 2008 Ford Supercrew short box with the 5.4, the tow package and 3:71 rear. I have installed Timbren overloads. The truck did fine with my previous camper, a Rockwood 8315 tt, although I used an Equalizer hitch. It is not economically feasible for me to replace the truck at this time.
I would really like to have a fifth wheel and the salesmen tell me that if I order the 5er with a factory installed sidewinder hitch I would be fine. Is there anyone familar with this product? I could sure welcome some real world experience and advice. Thanks in advance, Bill
MrBill is offline   Reply With Quote
Old 09-21-2010, 06:31 AM   #2
Head Rambler
From looking at the specs you might not be real happy with the performance but it doesn't look too bad for the TV you have.
The Sidewinder hitch is a personal choice there are lots of people towing a 5er on a short bed. Be sure to check with Forest River because in the past they voided the frame warranty if you used an extended hitch adapter.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 09-21-2010, 06:35 AM   #3
A slider hitch like the superglide would be a much better option. I tow with a shortbed with the superglide works great.
2011 Sierra 35 Loft TreeHouse
2006 Dodge 3500
Better Photo
Mowat is offline   Reply With Quote
Old 09-21-2010, 07:00 AM   #4
kvtaylor's Avatar
Another option is the Reese Hitch with a slider for the short back end. We did that with our GMC 2500 Crew Cab. Never had a problem. it had the short bed.
Ken and Velda
Dahlgren, VA.
2008 Georgetown XL 378
2010 Ford Escape Limited
kvtaylor is offline   Reply With Quote
Old 09-21-2010, 07:13 AM   #5
Now a "Top Member"
EdJunior's Avatar
Is your Ford a F-150 or F-250? If F-150, is the short bed the 5.5ft or 6.5ft? If it's the F-150, while the specs may bear it out, you are very likely to not be happy with the towing. Maybe if you only do short trips to local areas that don't involve many hills or mountains, but even then, the F-150 is just not really made for 5th wheel towing. I've seen enough of them, and some people are happy with it, but I'm just saying, an F-150 will struggle, for all it being a good truck.
If it's an F-150 with the 5.5ft bed, I wouldn't even consider it at all.
Ed and Sharon
2010 Wildcat 28RKBS
2011 Ford F-250 XLT, 6.7L PSD
Ride-Rite Airbags and Airlift wireless remote compressor...nice!
Old 09-23-2010, 08:44 AM   #6
I have a 2010 8265s with the reese sidewinder hitch, which was factory installed. I tow it with my 05' Nissan Titan ( 5.6' shortbed ). The truck tows great and the hitch works perfectly. I haven't had any problems.
skylarcamp is offline   Reply With Quote
Old 09-23-2010, 01:52 PM   #7
To me the superglide hitch is not worth the $1000 difference. They both serve the same purpose. Neither one of them is going to tow any different. As far as your tow vehicle, the 5er falls below your tow rating. It will depend on how much cargo you carry. It doesn't look like there was much difference in the weight of your TT and the new 5er so if you handle the TT okay then the 5er should be fine and will even pull easier. I just did the samething you did. I went from a TT to a 5er. The 5er weighs about 600-800 pounds more then my TT did, but pulls a whole lot easier. I couldn't believe the difference.
phoneman06 is offline   Reply With Quote
Old 09-23-2010, 03:05 PM   #8
The superglide is about 1500-1600ish with all the components.
The sidewinder is 800-900 for just the pin. Then 400-600 for the 5th wheel hitch itself.
The price is a wash. Just depends on your preference.
2006 Dodge 3500
Better Photo
Old 09-23-2010, 03:26 PM   #9
The sidewinder is only $400 when ordered from the factory on a new 5er so it will still cost you 200 to 400 more for superglide and you are not gaining anything. You also gain some cargo space in your bed because you don't have to worry about king pin box hitting anything because it does not move.
Old 09-27-2010, 04:43 AM   #10
What about the load rating on your tires? I am in the process of having a Curt 5th wheel hitch installed, but am now concerned that i will have a sidewall blow out unless i get some e-rates tires. Just something else for you to consider.
dambrino is offline   Reply With Quote
rockwood
