Old 06-14-2015, 01:25 PM   #101
ov845's Avatar
It is the rate of change. I'm not saying that psi of Nitrogen won't change, because it will. Air expands & contracts faster than Nitrogen, also can produce moisture (depending on the rate of expansion/contraction).
2012 Ram 1500 5.7L 3.92
2015 2809 WindJammer
ov845 is offline   Reply With Quote
Old 06-14-2015, 01:50 PM   #102
Herk:
In the case of tires, the volume is fixed and temperature changes causing pressure to change. The gas can be nitrogen or steam, it does not matter.
You are absolutely CORRECT.
But the nitro's mantra is "Give me the facts, so I can make an emotional decision!"
2011 Traverse LT, 3.6L, FWD
Old 06-14-2015, 02:15 PM   #103
schrederman's Avatar
The fact that this thread is still going is a testament that people get something in their heads and just absolutely HATE to be wrong... Human nature includes gullibility, unfortunately, and sales people play VERY heavily on that... and I'm not pointing fingers. I'm human, and guilty, too...
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 06-14-2015, 02:31 PM   #104
Herk7769's Avatar
Why would this be so?
What would cause that?
Is there an equation that describes that?
As to producing "moisture" I can see how that could be (since N2 is "dry" out of the bottle and air from a compressor compresses the humidity in the air along with the gas), but it would of course have absolutely no effect on that pressure or temperature of the gas - air - (which is what supports the load) in the tire.
The process of pressurizing the "wet air" actually dries the air quite a bit and that water then collects in the pressure tank which must be drained regularly to prevent your compressor from rusting.
The percent of water as a gas remaining in the compressed air would have to reach its saturation point temperature (Dew Point) in order to condense. Since the air would be quite dry once compressed, even if there was some gaseous water condensation any tire warming would make it be a gas again in short order.
HAM CALLSIGN - KC3FFW
Old 06-14-2015, 03:32 PM   #105
Anacortesians
BTW, tires "burst" they don't "explode", since usually, there's no combustion involved. That 727 incident I mentioned in my original post did explode, as it got hot enough to bring gaseous compounds out of the tire carcass that were flammable.
Analysis of the tire-beads (they failed in tension) indicated an instantaneous pressure inside the tire of close to 12,000 psi before it blew.
Frank and Eileen
No longer RVers or FR owners
Old 06-14-2015, 04:03 PM   #106
And you can measure the difference between 78% nitrogen and 100% nitrogen in a trailer tire? Bring on the data or calculations!
Old 06-14-2015, 05:18 PM   #107
ov845's Avatar
You're correct. But let's say you're driving thru the mountains (tires mounted on steel wheels) now tired pull off to get some rest on a cool spring night. Steel rims are going to retain heat longer from brakes being applied as to the tires cooling faster, the air in between may actually sweat. It doesn't take much moisture to start the process. But once it's there it's harder to get rid of it.
Old 06-14-2015, 05:39 PM   #108
ov845's Avatar
Without an nitrogen analyzer, no but just like anything else, it requires trust. As you said before, if you believe it works for you then stay with it, if not, then don't. Me personally, A good TPMS that also keeps track of temp would tell you.
Old 06-20-2015, 08:56 AM   #109
jdhreiss's Avatar
Nitro
Maybe in my Kawasaki..... ;-)
jdhreiss is offline   Reply With Quote
Old 06-20-2015, 09:13 AM   #110
prof_fate's Avatar
Interesting science read on the subject (true or not? you tell me)
Are Nitrogen Molecules Really Larger Than Oxygen Molecules?
The correct answer, with respect to “permeation”, is yes.
Graham’s Law Explained:
The Difference between Effusion and Permeation
http://www.getnitrogen.org/pdf/graham.pdf
Of course the bottom line is, does it matter in the real world? IMO, no.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
