Old 05-28-2015, 02:14 PM   #1
david345's Avatar
Nitrogen. Yes or no
Will putting nitrogen in my tires on my Rockwood 2608 help prevent blowouts. I just put a new set of Goodyear marathon 205 75r14c on the camper. The Goodyear dealer didn't mention it
david345 is offline   Reply With Quote
Old 05-28-2015, 02:23 PM   #2
DDC
DDC's Avatar
Yes possibly maybe and it should.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 05-28-2015, 02:41 PM   #3
cdangel0's Avatar
Nitrogen is a larger molecule than oxygen so the tires will not "leak" as much as fast, so less need to re-inflate.
Nitrogen is also supposed to run cooler that regular air - I only say supposedly because that's what I've heard - I've never tested the theory.
So if it does run cooler than air, and doesn't diminish air pressure while parked, thus leaving the tires inflated properly, it SHOULD help eliminate blow-outs not caused by road debris.
Craig & Lynn D'Angelo
Delaware
cdangel0 is offline   Reply With Quote
Old 05-28-2015, 02:50 PM   #4
MtnGuy's Avatar
I use 79% nitrogen in my tires.............it comes straight out of the air compressor.
Old 05-28-2015, 03:01 PM   #5
vinmaker's Avatar
Although opinions vary on the forum about this, there is a reason why FR spends the extra money to fill the tires of its units with Nitrogen.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 05-28-2015, 03:06 PM   #6
Ashley's Avatar
X2 ^^^^ and then as the smaller molecules of the other 21% keep leaking out, I top it off again and again using my handy dandy air compressor and figure sooner or later I'll end up with 99% percent Nitrogen by filtering out the other stuff.
Sorry, not being a smart butt, just having a tough afternoon and needed a little laugh for myself.
2008 Dodge Ram 3500 MegaCab 6.7 Cummins
4x4, 4.10 Gears, 68RFE Trans
2012 Primetime Lacrosse 318 BHS
Ashley is offline   Reply With Quote
Old 05-28-2015, 03:07 PM   #7
MtnGuy's Avatar
Me thinks Forest River uses it as a ploy to sell more units.
Unless the tires are filled while in a vacuum, it is impossible to get 100% N2 in the tires. The volume between the unfilled tire and wheel contains air, which will still be there after filling with N2. If you repeatedly empty and refill the tires, you might get close to 100% N2, but I doubt the manufacturers go to that kinda trouble.
So my question here is: Is ~95% nitrogen that much better than 79% nitrogen ??
Old 05-28-2015, 03:15 PM   #8
Taranwanderer's Avatar
One of the greatest posts of all time. You win the Internet today, sir.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 05-28-2015, 03:18 PM   #9
Oaklevel's Avatar
Purely a waste of money if you are putting it in your tires it prevent blowouts. It will NOT do that.......... Tire pressure & proper loading more important.
As far as Forest River using Nitrofill in our tires they probably pay almost nothing to do it. Nitrofill is advertising on the sides of the trailers. Our car dealer when he first started using Nitrofill it was an extra $39.99 But that included an insurance to replace tires if they were damaged (road hazard). Now he must of got tired of complaints as there is now, no extra charge. We got the same or worse wear on tires of the junk Subaru we bought from them with Nitrofill.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 05-28-2015, 03:37 PM   #10
Witch Doctor's Avatar
Nitro, will run the tire temp cooler, as far as the vacuum. If they use the machines it will vacuum out any air in them. That is the main reason they use it in Plane tires, Also your PSI is more stable then compressed air. It is also supposed to stop tire rot. Compressed air has water molecules in it to where Nito is dry. This is the reasons right or wrong. When I changed tires I did not buy it, just plain old air.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
