Old 05-24-2012, 09:59 PM   #1
no ac power
I have a 2008 rockwood 2607. I plugged it into the house and no power. All fuses have been checked anyone have any good ideas
Joseph5410 is offline   Reply With Quote
Old 05-24-2012, 10:17 PM   #2
Herk7769's Avatar
Is there power where you plugged it in?
Is it a switched outlet for instance?
Verify good power with a voltage tester.
Is there voltage at the power panel?
Check Breakers - one (the biggest one) - is the main.
Do you have 12 volts? Do your lights work?
HAM CALLSIGN - KC3FFW
Old 05-24-2012, 10:32 PM   #3
caper's Avatar
Is the house outlet GFI. If it is check outlet the trailer has a GFI also. Because of the two GFI on same circuit one will trip.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 05-24-2012, 10:53 PM   #4
Iggy's Avatar
AC is not on a GFCI circuit
Old 05-25-2012, 08:21 AM   #5
caper's Avatar
They original poster said he was plugged into the house and has no power. This could be caused by a GFCI that has tripped. They did not say that they did not have DC voltage that would not be protected by a GFCI. All AC should be protected by a GFCI.
Terry and Janet
2007 Ford F150
Old 05-25-2012, 09:02 AM   #6
FreedomTracker's Avatar
I am also having the same problem. Generally I like to plug into shore power the night before a trip just to ensure good charge and to get the fridge cold.
I have checked all the breaker (house/TT) and GFIs... all good. Sometimes I can get power to TT but when I turn AC on, power will shut back off. I am also using EMS surge protector.
2012 Ford F150 4x4, 5.0L, 3.55
2011 Rockwood MiniLite 1809s
E2 WDH 600/6000lbs
FreedomTracker is offline   Reply With Quote
Old 05-25-2012, 09:36 AM   #7
TURBS's Avatar
Did you try it without surge?
Old 05-25-2012, 09:37 AM   #8
I have dc power and gfi or gfci is ok. I plug camper into house sometime i have very dim lites sometime nothing. I was wonder if this was signs of power converter going bad
Old 05-25-2012, 09:40 AM   #9
TURBS's Avatar
How old is your battery? Is it bad?
A bad battery will cause issues.
In the faq section there a way to also test your converter if its a wfco brand.
Old 05-25-2012, 09:41 AM   #10
Have not tried w/out the surge thinking maybe it was protecting the TT electronics. Wouldn't that be defeating the purpose of have the surge protector? Thought about it though...
E2 WDH 600/6000lbs
led pad
