Old 04-07-2015, 10:40 AM   #11
redcloud1's Avatar
Found it, you can get to it without having to take the drawers out or any panels off. you can access it from the bottom storage space below the to drawers in the kitchen counter.
redcloud1 is offline   Reply With Quote
Old 04-07-2015, 10:47 AM   #12
TURBS's Avatar
Good job!
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-07-2015, 02:06 PM   #13
Go git em Redcloud.
FOREST RIVER FW 8524RLWS
2010 FORD F 150 5.4
#1-18' Nomad #2- 20' Mallard #3- 27' Sunline #4- Four Winds C #5- Innsbruck 40' PARK # 6- 28' Amerilite #7- Forest River 26.5 FW ( 1st FW)
SULTINI is offline   Reply With Quote
Old 04-07-2015, 03:30 PM   #14
redcloud1's Avatar
Thanks guys. well at least when I put the water to it this weekend if the hot water tank doesn't fill with water I don't know that the valves need to be switched over
Old 04-07-2015, 07:46 PM   #15
jkeezer's Avatar
Originally Posted by OldCoot View Post
Years ago, we just drained all the lines and the water heater, blew the lines and poured anti freeze in the traps and let it go. Never had frozen pipes either.
X2.. always done it that way and never had a problem
2015 Cedar Creek 38CK
jkeezer is offline   Reply With Quote
Old 04-08-2015, 05:43 AM   #16
I always pump it(non tox antifreeze) through the system using the demand pump. Then hit the traps. Never know where a low spot will be that the air can't blow out completely.
2010 FORD F 150 5.4
bypass, hot water, tank, water, water tank
