Old 04-06-2015, 06:52 PM   #1
redcloud1's Avatar
No bypass on hot water tank
Does anybody know how to winterize a Windjammer 3008 when there is no bypass that I can see on the hot water tank? I found the bypass for the antifreeze hook up under the bathroom sink. Do I have to install the bypass on the hot water tank?
redcloud1 is offline   Reply With Quote
Old 04-06-2015, 07:12 PM   #2
Oaklevel's Avatar
If you have a bypass it should be on the back side of the water heater. You may have to take off a panel to get to it.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 04-06-2015, 09:20 PM   #3
Friends have a Windjammer 3008. There is a panel on the lower right in the entertainment center that he took off to gain access to bypass.
Wiscampsin is online now   Reply With Quote
Old 04-06-2015, 09:24 PM   #4
Years ago, we just drained all the lines and the water heater, blew the lines and poured anti freeze in the traps and let it go. Never had frozen pipes either.
Old 04-06-2015, 09:29 PM   #5
If it is a 2015 you have a W/H bypass. Youroo!!
Old 04-07-2015, 04:34 AM   #6
redcloud1's Avatar
Do you know where it is located? I have looked at the back of the tank and don't see the bypass.
Old 04-07-2015, 05:12 AM   #7
Dazed & Confused
M&K Hoffman's Avatar
I own a 3008W and mine bypass valve was easy to access by simply removing the two drawers in the end of the kitchen peninsula.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 04-07-2015, 06:02 AM   #8
redcloud1's Avatar
Ok I'll have to check that out.
Old 04-07-2015, 07:20 AM   #9
TURBS's Avatar
You have one, you just haven't found it yet!
Good luck.
Remember to post back with pics if possible so it might help others!
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-07-2015, 07:57 AM   #10
redcloud1's Avatar
Ok
bypass, hot water, tank, water, water tank
