Old 05-12-2014, 03:50 PM   #1
PMQ
No power to slide out
2014 Rockwood Ultralite 2909ss has not been camping yet. Just finished de-winterizing and retracted slide out. Now trying to open 2 hrs later and there is not a peep when pressing slide out???? Camping booked I 2 days help!
Sent from my SGH-I317M using Forest River Forums mobile app
PMQ is offline   Reply With Quote
Old 05-12-2014, 04:07 PM   #2
KMP44's Avatar
Sounds like maybe a blown fuse. Check your wiring underneath. On ours, there is a 30 amp flat blade fuse in the power supply to the slide motor. If everything else has power, I'd start there.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 05-12-2014, 09:14 PM   #3
Yep blown fuse. Happened to me too, brand new 2014. The fuse for mine was located on the frame where the wiring goes underneath the trailer. Just follow where your trailer plug cable goes. I replaced it with a 30 A automatic reset circuit breaker. Problem solved.
gserve is offline   Reply With Quote
Old 05-12-2014, 10:02 PM   #4
PMQ
Thanks guys...im going to bring a fuse kit and check the fuses
Old 05-12-2014, 10:47 PM   #5
Yeah. It seems any little catch or bind in the slide mechanism blows that fuse.
My slide wasn't 100% square and straight when I bought my TT and I probably went through a half dozen fuses until I could get into the dealer and get the slide fixed and straightened under warranty. It hasn't blown a fuse since.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 05-13-2014, 08:25 AM   #6
ejknight's Avatar
check the 30 amp fuse. we had the same issue on our 2703ws.
Also check that the battery has a good charge, a low battery under load can cause some weird things to happen.
2015 Ram 1500 5.7 V8
2014 Rockwood 2703WS
Days Camped in 2016: 34 (A New Record!!)
Days Camped in 2017: 25 (so far)
ejknight is offline   Reply With Quote
Old 05-13-2014, 10:04 AM   #7
PMQ
Thanks everyone! It was the 30 a fuse underneath....blown. good to go now
Old 05-19-2014, 12:40 PM   #8
Ejknight. How do you like your 2703ws. Am looking at buying one and would appreciate your thoughts. Thanks
ccannon is offline   Reply With Quote
Old 05-19-2014, 12:53 PM   #9
ejknight's Avatar
So far so good. the wife and I love the floor plan, Tows a bit light but I usually add about 1/2 tank in the freshwater tank to help that. I've had a few minor issues with mine:
Toilet leaked 1st trip out...
Blew fuses on WR slide and DR Slide
and had a leak on the DS rear window
Took it to my local dealer and they fixed everything and also installed a re-settable CB to fix the fuse blowing issue...
Now my only issue is being able to take time off to enjoy it!!!
power, slide, slide out
