Old 07-04-2011, 04:53 PM   #1
Angry No power to slide out on rockwood 8314ss
I don't have any power to the slide out and I can't find the fuse. It is out about 10" is there a way to manually crank it in?
Dan-Donna is offline   Reply With Quote
Old 07-04-2011, 05:07 PM   #2
The slideout fuses are just behind the tongue on a travel trailer, underneath the frame. Follow the wires from the slide motor to the front underneath, and you should see a green plastic case with an automotive style 30 amp fuse inside. This should solve the problem. Randy
Old 07-06-2011, 04:28 PM   #3
You can also crank in the slide out if you have a more recent rock-wood the place to crank it in ahold be on the opposite side of the camper that the slide out is located on it might be in the stair well and it is normally a gold crank
Matthewsbj1 is offline   Reply With Quote
