Old 11-23-2012, 07:47 PM   #1
RalphieAdie's Avatar
Okay...it's official...HATE the water filter!!!!!!!!!!
Besides being in a very awkward location and impossible to remove to winterize without slopping water out of it. Today, as it wasn't re-installed properly, it leaked water all over the inside of our unit! So, who has completely eliminated the filter and simply installed another piece of waterline in place of the filter inside the unit?
Ralph & Adrienne
2016 Flagstaff 8528CKWSA
2012 GMC Sierra 2500HD 6.0L
RalphieAdie is offline   Reply With Quote
Old 11-23-2012, 08:01 PM   #2
indybp57's Avatar
This was my first year for winterizing a TT. I started by using an air compressor and blow out plug. I found that it forced most of the water out of my filter, eliminating the water slopping out when I removed the element. I have also opened it up when full, placing a small flat pan under it to catch any sloppage. Is the filter really necessary? In my opinion no, since we camped for over 20 years in tents and PUPs and never getting sick from bad water, but we have always camped in campgrounds with modern water systems. It's probably most useful for killing bad taste that gets picked up from the fresh water tank. Many people keep bottled water for drinking and using the fresh water tank only for washing dishes and showering.
indybp57 is offline   Reply With Quote
Old 11-23-2012, 09:42 PM   #3
We have left the filter cartridge out of ours. Just using the clear spin on cover to close the water system. Instead we use one of the filters that go inline with the fresh water supply line. First piece on the hose bib is pressure regulator, inline filter, hose to fresh water city connection on TT. When filling the fresh water tank, put filter on bib, minus regulator, then hose and fill tank.
2004 F150 4.6 Griffin tuned
2010 Wildwood 24FBS
johnleann is offline   Reply With Quote
Old 11-23-2012, 09:49 PM   #4
Herk7769's Avatar
Water filter is gone and a 2 gallon surge tank is in its place.
Love the quiet flushes at night when boondocking.
HAM CALLSIGN - KC3FFW
Old 11-23-2012, 10:02 PM   #5
Good idea herk7769
2010 Wildwood 24FBS
Old 11-23-2012, 10:10 PM   #6
Nigels's Avatar
Thats got me thinking and that can be dangerous Would that surge tank give me 2 gallons of water for flushing when on the road, without filling the tank and using the pump?
Nigel & Bev
Brit Driver & Canadian Naviguesser
2011 Rockwood Signature Ultra Lite 8280ws
2011 Dodge Ram 3500 4x4 Diesel
Nigels is offline   Reply With Quote
Old 11-24-2012, 06:11 AM   #7
Herk7769's Avatar
Yes to "without using the pump"
Yes to "without filling the FW tank" - Provided you understand the pressure will drop as the water is used and the maximum starting pressure is determined by the water pressure used to pressurize the system and the air pressure in the tank.
If you use the water pump to pressurize the system, that will be about 35-40 PSI of water and it will hold that pressure until the tap is opened. As the water is used be cause the air in the expansion tank will push the water out of the tank at the pressure of the air.
There is an optimum setting for the "unloaded" air in the expansion tank (you will need to play with this number for your particular rig.
When the expansion tank is full of water, the air pressure reading must be higher than the "ON" pressure of the pump; but lower than the "OFF" pressure so the tank holds the most water possible yet will completely empty if needed.
Old 11-24-2012, 07:34 AM   #8
KyDan's Avatar
Just wanted to add to your question, you could temporarily connect to city
water inlet just to pressurize your surge tank and water lines even with a dry
fresh water tank. Then you'd get a bit of water out of a faucet or toilet until
the surge tank was empty.
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 11-24-2012, 07:45 AM   #9
KyDan's Avatar
Hey Ralph, I took out my water filter the 1st time I tried to winterize it.
Like you- mine was in a terrible place to reach and there was no way to
empty it without making a mess AND it didn't have a bypass so if I wanted
to pump pink antifreeze thru the system, it was going to take half a gallon
just to fill the #$%&! water filter housing.
AND some folks have reported that their water filters cracked when left
absolutely full of antifreeze!
I bought a brass 1/2 pipe coupling (might have been 3/4 pipe in the filter housing?) and removed the fittings out of
both sides of the water filter housing and just put the coupling in the place
of the filter.
Then I went to Home Depot and got a whole house filter for about $30.
I then added brass garden hose to water pipe fittings on each side.
One side is male hose and the other side is female hose.
I put that on my city water inlet and connect the city water hose to it.
I still get filtered water but it's easy to tip on it's side and drain when not
in use.
I even use it on a hose to fill my fresh tank when we're going boondocking
so my fresh tank is full of filtered water.
Look for a whole house filter with a built in shut off for more convenience.
I just put a little garden hose ball valve on one side of mine.
Probably could have used the filter out of the trailer but in my case I
already had the outside filter setup from a previous trailer.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 11-24-2012, 07:55 AM   #10
We took ours out of our last rv early on. Our water here is not real good so we don't drink from the tank, we bring RO water that we bottle at home.
Filthy Beast is offline   Reply With Quote
