Old 05-17-2014, 09:01 PM   #1
One side of slide won't retract
I have a 2006 Rockwood 8280 and one side of my slide will not retract. Does anyone know why this might be happening. Thanks!
yzf02inblue is offline   Reply With Quote
Old 05-17-2014, 09:16 PM   #2
Not enough Info but sounds like a (Shear Pin) in (1) gear on (1) side! Youroo!!
Old 05-17-2014, 09:44 PM   #3
Mod free 5er
X2
Old 05-17-2014, 09:51 PM   #4
Hans's Avatar
ok, if it is a shear pin, what would the fix be?
Hans is offline   Reply With Quote
Old 05-17-2014, 09:55 PM   #5
Herk7769's Avatar
There is a timing shaft that connects the two racks.
The motor drives a screw in the center and the timing shaft keeps the two sides in sync as it moves in and out.
As everyone who answered stated you most likely lost a shear pin (broken or fell out) that ties the rod together. You might see one in the photo of the cross rod and the gearpack.
Name:	9 Nov 2009 006.jpg
ID:	52651   Click image for larger version
Name:	9 Nov 2009 005.jpg
ID:	52658   Click image for larger version
Name:	Horst Probe Install 024.jpg
File Type: pdf 0002-gear-pack-replacement-embedded-rack.pdf (144.8 KB, 40 views)
Old 05-18-2014, 06:23 PM   #6
I found it! The shear pin on the crossbar on the right side was on the ground. It had sheared off. It looks like a simple bolt and lock nut fix. Thanks guys for your replies! Danny in California
Old 05-18-2014, 06:28 PM   #7
Professional Texan
TexasBob's Avatar
The bolt will get you out of a bind but it has a shear pin for a reason. Shear pins are cheaper than gears.
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 05-20-2014, 08:23 AM   #8
Oops. I meant, another shear pin and lock nut fix. Mission accomplished and slide working properly again!
slide
