I have a 2013 Rockwood Sig Ultra Lite 8306, been camping in it twice. Above the dinette is a large window with a screen. The window is an emergency window with a lever below it with a red tip. On the window is a sticker warning it is an emergency window. It says if you pull the lever towards you it will pop the screen out and then push the lever out to open the window.
Can I use this window for everyday ventilation? The sticker wording is just so ominous like never ever under any circumstances should you use the window except for a dire emergency. I was afraid if I opened it that it may fall to the ground
