Old 06-23-2016, 07:35 PM   #1
Outdoor tv mount location
Hi, looking to mount tv bracket near the cable and 110 outlet on a 2015 8329
Funbobby is offline   Reply With Quote
Old 06-23-2016, 07:53 PM   #2
CaptnJohn's Avatar
8329 ??? My 5er came cable and 110 ready in the pass through....
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 06-23-2016, 08:06 PM   #3
Left Coast
Pull the pass-thru wall plug, put a splitter in, run a coax down through floor, tie wrap to propane line, and pull the outside 120 receptacle, add a coax (male to male) connector to wall plug face plate....when you get to 120 receptacle, go back up thru floor and make your connection.....can buy PAW wedge style mounts on amazon..
Old 06-24-2016, 02:04 PM   #4
hi, sorry, what I need is where to mount the actual bracket on the outside exterior wall. the actual location so I am screwing into solid material. the 110 plug and cable hook up is already there
Thansk
Old 06-24-2016, 02:15 PM   #5
nomad297's Avatar
This is what I use for my 48" TV. I can put the TV wherever I want, whenever I want.
GOstik Products Flat screen TV Suction Cup Mount | GoStik
Bruce
Old 06-24-2016, 02:23 PM   #6
Left Coast
This holds just fine....use 1 1/4" sheet metal screws with caulkingClick image for larger version
Sent from my XT1585 using Tapatalk
Old 06-24-2016, 02:25 PM   #7
Left Coast
But a cheap adjustable mount at Wally world....No wall is solid, but if you hand drive #12 screws in, you'll be fine....
cat, door, location, mount, tv mount
