Old 10-05-2015, 01:25 PM   #1
Outside tv mount on 2703ws
I just purchased a 2014 2703 travel trailer and noticed there is a hanging TV mounting bracket outside. Does anyone know if I can use the mount from inside to hang outside or do I need buy a separate mount?
Thanks.
2014 Rockwood 2703 WS
2014 Chevy Silverado 1/2 ton
benitslu is offline   Reply With Quote
Old 10-06-2015, 09:14 AM   #2
jeff64's Avatar
On mine you can. You need to pull the tv away from the wall and smack the bracket where it goes into the wall mount and it will slide up and out on the two keystone slotted holes. If yours is like mine.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 10-06-2015, 09:38 AM   #3
Ejs4029's Avatar
Are you talking about the rear TV ? Or the bedroom TV ? I noticed when trying to move the bedroom TV to the outside mount that you will need to get a longer piece of cable to plug it in since the one provided in the bedroom is to short.
Ejs4029 is offline   Reply With Quote
Old 10-06-2015, 11:35 AM   #4
I have have a tv in the living room. I looked at it last night and looks like it will work, as described above.
Old 10-10-2015, 12:04 AM   #5
ejknight's Avatar
I have a 2014 2703ws and yes the tv in the living area is designed to be used on that bracket on the outside of the of the trailer
2015 Ram 1500 5.7 V8
2014 Rockwood 2703WS
Days Camped in 2016: 34 (A New Record!!)
Days Camped in 2017: 25
Days Camped in 2018 - Not Nearly Enough!
ejknight is offline   Reply With Quote
Old 10-10-2015, 06:50 PM   #6
It is the bedroom TV and the cable does work. See pic attached.
Roll Tide!
CCWAKERIDER is offline   Reply With Quote
Old 10-12-2015, 08:25 PM   #7
I got it to work this weekend. Thinking about putting a tv in the bedroom with the same mount and bracket. Where can you buy this particular set up? Hoping it's not a dealer item...?
Old 10-12-2015, 09:43 PM   #8
I did not see the mount name on it, but most likely comes from the dealer........ Glad you got it to work, and hope you enjoy
Old 10-13-2015, 07:18 AM   #9
jeff64's Avatar
I got mine direct from forest river. Year, make model number and serial number will get it for you( and of course a C-note!)
14K Equalizer
Old 10-13-2015, 07:24 AM   #10
How much was it from FR?
mount, tv mount
