Old 02-20-2012, 10:09 AM   #11
Newbie
pg_rider's Avatar
Thanks everyone. As someone said, RVW sells the starter kit as an option and I didn't choose it, so I'm assuming they won't just throw it in. Went to WalMart last night and picked up a Rhino sewer kit, Lynx levelers, and wheel chocks so I'm good there. Guess I'll wait and see on the fresh water hose and other accessories.
2012 Rockwood 2306
2007 Honda Ridgeline tow vehicle with Equal-i-zer and Prodigy P2
pg_rider is offline   Reply With Quote
Old 02-20-2012, 11:04 AM   #12
DAISY BOYKIN's Avatar
Rhino sewer hose is good!
For the people that have purchased a new (or used) RV during the winter months, make sure when you get it to your destination that you wash all the salt from underneath the RV. Use a pressure washer if necessary or strong hose stream. Use a chemical called "KLEAN STRIP" phosphoric prep & etch, can be applied with a brush or pump up bug sprayer. Follow directions carefully, can be purchased at Lowe's or Home Depot in the paint department. After using the chemical as per directions, paint with a good coat of Spray "RustOleum" . You can fill in the open end box portion of the frame that supports the axles with the foam insulation in a can. After is dries and swells up, simply cut of the excess with a hack saw blade.
KLEAN STRIP is also known as OSPHO!
For the one that have two dump connections and dump valves you cannot reach, here are some pictures of a suggestion.
Name:	GRAY TANK REMOTE DUMP 003.jpg
ID:	10477   Click image for larger version
Name:	GRAY TANK REMOTE DUMP 008.jpg
ID:	10478   Click image for larger version
Name:	GRAY TANK REMOTE DUMP 010.jpg
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 02-21-2012, 12:07 PM   #13
Newbie
pg_rider's Avatar
Originally Posted by punkaccountant View Post
PG, I ordered a 2306 about the same time you did. Do you know if your unit will be a 2013 year model or not?
Good question, and I have no idea! My purchase agreement references 2012, and my sales guy has made no mention of it being a 2013. So, unless the factory switches over to the new model year and makes my 2306 a 2013, I'm guessing it'll be a 2012...
2012 Rockwood 2306
