Old 11-01-2013, 06:00 PM   #1
PhoneDude 8289's Avatar
Pin weight
Is the advertised hitch weight of 1524 lbs based on the dry weight or the GVWR of the 8289WS.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 11-01-2013, 06:09 PM   #2
On their spec sheet it calls that a "dry hitch weight". 1828 would be a more realistic loaded pin weight.
Old 11-01-2013, 06:28 PM   #3
Fulltime family RVer
Yup.
Old 11-01-2013, 06:30 PM   #4
In fact, you can use the percentage of the dry weight to dry pin weight to use in estimating actual loaded pin weight. The wet pin weight is usually about the same percentage as the dry or another 1 - 1.5% higher. But it helps in planning.
Old 11-02-2013, 08:31 AM   #5
canterburyshoe's Avatar
I weighed mine before we left for a week of camping. Hitch weight came in at 1740#
2013 Rockwood 8289WS
2017 F350 6.7 PS extra cab long bed
Curt G25 hitch
Days camping 2016 - 26
canterburyshoe is offline   Reply With Quote
Old 11-02-2013, 08:51 AM   #6
Out of curiosity- what was the camper's total weight? Just curious about the pin weight percentage.
Old 11-02-2013, 02:57 PM   #7
8720# total weight and 7000# exactly on the axles.
Curt G25 hitch
Old 11-02-2013, 05:34 PM   #8
Thanks. So my earlier comment stands- dry pin weight % was 19.5%. And your loaded pin weight % was 19.9%.
Old 11-02-2013, 05:45 PM   #9
Witch Doctor's Avatar
My real pin weight is 1675 lbs. if that helps but remember it is also after you you are loaded for camping. I did it at a cat scale on a trip just for the hell of it so I would know if I was over loaded but that whats my pin weight came out to be. I think I was under the 1600 or so they said I could carry on the sticker on the side and on the screen door.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
weight
