Old 07-29-2015, 12:21 PM   #11
When you purchased your trailer, it should have come with a crank that can manually move the slide. Our trailer came with a single crank that can operate both front jacks and the two larger slides. The third small slide also was supplied with a tool that attaches to a cordless drill and allows for manual slide operation. If you don't have that crank tool, you should be able to find it at a dealer. Here is a video that shows the crank in operation. This is the crank I have for our TT.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 07-29-2015, 01:15 PM   #12
Please help locate manual crank for slide on 2004 rock wood 8285ss
I have a 2004 Rockwood 8285SS. The slide is on the left side of the 5W. The motor and manual hookup are under the rear of the slide. I took a deep-well socket and slotted for a roll-pin in the manual shaft. I would have to turn it by hand with a ratchet wrench; time consuming.
zalewskim is offline   Reply With Quote
Old 07-29-2015, 01:26 PM   #13
BamaBob's Avatar
Having had to retract our slide when the power went out, I know from experience that it is not that big of a deal to manually retract a slide.
Now the closet electric-gear operated slide in the bedroom is a WHOLE different story!! Gimmie my cordless drill for that bugger!
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
cat, manual, slide
