Old 06-30-2016, 10:10 PM   #1
Plugging in at home
We are going camping this weekend and I went out to plug the camper in to start up the fridge and when I plugged in the camper to the house outlet ( WHICH IS A GFI ) it trips the GFI everything I try it. But when I plug in anything else it works fine. This is the same outlet we've used for a long time,I even replaced the GFI and it still does it. But, if I plug in the TTYL into a room inside the house everything works just fine,any suggestions ?
cruiser1701 is offline   Reply With Quote
Old 06-30-2016, 10:28 PM   #2
Ford Idaho's Avatar
You are plugging in one GFCI circuit into another one, generally the two do not play well with one another.
If you have a none GFCI outlet use it.
Old 06-30-2016, 10:31 PM   #3
Broadway Joe's Avatar
Lots of time 2 GFI's in the same circuit will cause one of them to trip, usually at the source, your house. If possible while plugged into a different outlet,trip the GFI in your camper. All should be ok now plugged into your house GFI.
Joe
2015 Wildwood 27RKSS
2015 Silverado 2500HD Duramax
Broadway Joe is offline   Reply With Quote
