Old 07-12-2010, 07:38 AM   #1
Nights Camped in 2010 - 2
Plumbing question
Good Morning.
Here is a real newbie question, so I apologize up front. Does the water from the city connection flow through the water tank or straight to the facets and hot water heater? I am going to sanitize my system this week before installing my filters and I am trying to figure it out and understand the flow.
Also, I have the by pass set up. Is that used to by pass the hot uu water heater? Being a retired Navy guy, drawings would make life simpler. Any place to get them?
Thanks,
George Kelly
2011 Rockwood Ultra Light 2604
Dodge RAM 1500 Larime 4x4, 5.7 HEMI
Nights Camped 2010 = 18
Nights Camped 2011 = 15
sailingsuppo46 is offline   Reply With Quote
Old 07-12-2010, 07:48 AM   #2
Hello and welcome. In answer to the question, NO, the city water connection only pressurizes the lines. The pump, on mine anyway, has a check valve that won't let line pressure back in to the tank. I think most trailers are this way. There is also a check valve at the city water connection, so when it isn't being used, line pressure will not be leaking out onto the street. Drawings will be hard to find.
tank - pump - cold line (various "T"' to fixtures & Water Heater) -check valve- city
Water Heater - (various "T" Fixtures)
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 07-12-2010, 09:36 AM   #3
Originally Posted by sailingsuppo46 View Post
Good Morning.
Thanks,
This link will help you understand the water system: http://www.marxrv.com/plumbing/blkdia1.gif
AND..after you print out the diagram, where the red and blue lines enter the water heater, add a line connecting them with a valve symbol on it. That will be how the bypass system is connected.
Hope this works for you.
...VTX-AL (Retired Navy also , but - the Canadian version )
VTX Al is offline   Reply With Quote
Old 07-12-2010, 01:39 PM   #4
VTX,
Thanks. This works great. Worked a bit with your Navy guys a couple of years ago. Had a blast celebrating Canada Day. Heck of a bunch if golfer too.
George Kelly
rockwood
