Old 07-29-2007, 09:52 AM   #1
Cookie1322's Avatar
Pools of water on the roof
Hi everyone, this is my first post on this Forum. We now have a 2008 8318SS, I have noticed there is lot water standing on the roof after a rain or after the air conditioner has run for a while. When I jack the front down the water will come off like a water fall on me. Is this normal. I don't belive it is, I will be talking to the dealer soon. I was just wondering if anyone else has this problem.
Thanks, Cookie1322
Cookie1322 is offline   Reply With Quote
Old 07-29-2007, 10:59 AM   #2
milzat's Avatar
Hi cookie,
Welcome to the forums.
This is normal with a flat roof.
Water will stand in some areas. When setting up at a camp site, I usually back onto a 1" X 6" piece of wood with the curb side tires, so the water will drain on the street side.
When we break camp and I'm hitching up to my TV, as I'm raising the tongue with the jack, water runs off the rear of the roof as you described.
milzat is offline   Reply With Quote
Old 07-29-2007, 11:14 AM   #3
RAC
One way to look at this "problem" is that the water IS pooling.....means it isn't draining INSIDE the trailer.....that's a good thing. Just raise it all the way to dump water off back before you lower it. Happy Trailering!!
RAC is offline   Reply With Quote
Old 07-29-2007, 07:47 PM   #4
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Condensate running off the roof is normal. The answer is to keep your tailer tilted a bit to facilitate the runoff, as previously mentioned. However, lots of water could indicate a problem, such as a low spot in the roof. Level the trailer and run water from a hose on the roof. Then get up on a ladder and take a look. You should not have "pools" of water on the roof. You probably don't have a problem, but why worry about it?
dimurrrw is offline   Reply With Quote
Old 07-30-2007, 03:57 PM   #5
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
I gotta say...pooling water of any sizeable amount should be eliminated. Care should be taken to keep the roof from being completely level. I always set mine up with the tongue higher...just to be sure. My old trailer had a rear slide out...and if you didn't keep it tongue/high...it was prone to get water thru the seal.
All that water will eventually find it's way through a sealant crack, or seam. Plan for drainage when setting up.
That's just my experience...
Welcome to the forum.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
rockwood
