Old 09-17-2012, 03:24 PM   #1
Poor reception
I have a 2013 rockwood model 8315 bss. I get really poor fm radio recp. I can put my portable right next to it and it is fine. Is there a power booster avail? Or do i have a weak radio. The antenna is fine. Any ideas?
KIMMARK is offline   Reply With Quote
Old 09-17-2012, 03:33 PM   #2
Triguy's Avatar
What radio do you have? My Genesis pulls in FM pretty good.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-17-2012, 04:09 PM   #3
VinceU's Avatar
Mine was that way new, turns out the antenna was't there but not plugged in.
Old 09-18-2012, 07:39 AM   #4
Originally Posted by triguy View Post
what radio do you have? My genesis pulls in fm pretty good.
it is a genesis gt-3.0
Old 09-18-2012, 12:18 PM   #5
Triguy's Avatar
Mine is a Genesis 2.0, but they probably use the same tuners.
I think VinceU might be onto something. You mention the antenna is fine, which I assume means that you have it in the upright position. Did you also pull the unit to check for loose connections? At least that would be one of the first things I would check.
Assuming that isn't working, you can give Bob Fields a call or shoot him an email. He's also a member here if you want to PM him instead.
Bob Fields
bfields@concertone.com
574-343-1165 - Elkhart Office
Scott
2012 Shamrock 233S
