Old 03-24-2015, 11:09 AM   #1
pastorscottz
Power Awning Adjustment
I have a 2015 Rockwood 8285IKWS 5th wheel with the power awning. However, when the awning is fully extended, it is almost completely level. I have to adjust the level manually by pulling down on the extension arms and then tightening the clamps so that the rain will not pool. Then I have to loosen them again when I bring the awning in. It seems to eliminate the convenience of having a power awning. Would this have been installed by the dealer or at the factory? Was it their responsibility to have installed it so that it is ready to go without adjustment, or is it standard that even power awnings have to be adjusted after being extended? Anyone else have this issue?
Scott Ziegler
2012 Ram 1500 Hemi
pastorscottz is offline   Reply With Quote
Old 03-24-2015, 11:13 AM   #2
fonzie's Avatar
That is the way these work......
Fonzie
Old 03-24-2015, 11:25 AM   #3
Witch Doctor's Avatar
Make sure you don't over extend them, that will flatten them out, as for rain run off no other way around it.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 03-24-2015, 05:38 PM   #4
pastorscottz
Thanks, I appreciate the help!
Scott Ziegler
2012 Ram 1500 Hemi
awning, power
