Old 03-17-2012, 12:07 PM   #1
Problem with slide
We have a 8315BSS and the super slide wont go out. Do you know if there is an inline fuse and where it is located? My husband has checked the fuses and they all see ok and can't find the fuse for the superslide. Any advice will be greatly appreciated. Thanks
wishful traveler is offline   Reply With Quote
Old 03-17-2012, 12:33 PM   #2
TURBS's Avatar
Fuse should be in fuse panel/converter box.
I suggest replacing it with self resetting circuit breaker
Old 03-17-2012, 03:00 PM   #3
Do you know where in the panel the fuse might be? the listing on the panel does not say which one is the fuse for the super slide. The only thing that is not working is the slide, every thing else seems fine. Thanks
Old 03-25-2012, 07:58 AM   #4
I had a similar problem last year on 2604. Went to put slide in-- nothing. No sound, nothing. Crawled under trailer tongue near 40 amp breaker and found an in line fuse. checked fuse , seemed ok. reinstalled, same problem. Removed fuse again, cleaned prongs on fused with knife, reinstalled, worked.
stevieboy is offline   Reply With Quote
Old 03-27-2012, 02:59 PM   #5
I have a 2902SS and my slide fuses are under the trailer tongue, back behind the propane tanks. On mine, there's an in-line 30A fuse for each slide.
When I picked my camper up new and took it on its maiden voyage, neither slide worked... Turns out both fuses blew. On my camper, if I don't bump the switch when the slide motor gets under pressure, it will blow the fuse. I'm sure it's not right, but I can live and adapt to it...
On mine - Looking from the front of the camper to the back, the fuses are on the right hand side just under the front of the camper.
kwkincer is offline   Reply With Quote
